Project Information
This is a cutting board I made in class. I start d by selecting the wood, the board had to be at least 14 inches, so I cut the five pieces down to 16 inches to start, after that I glued them together. When the glue was done drying I chizzled the couple spots were glue dropped threw. When glue was gone I plained the wood down so all the pieces would be even. After planning I sanded it and put a coat wood protection (stuff to protect wood, I don't exactly know what it's called) and after the coat dried a put another one on when second coat dried I took it home a out it to use
Gallery
Comments
If it were me and I planned to eat food prepared on it, I'd want to make sure the wood protecting agent I used was food safe as well as the glue holding it together.
From what I gather, mineral oil is a popular finish. I used extra virgin olive oil on mine because it was the only oil I had on hand other than some used 5W20 and that's for quenching at the forge.
Andy, the type of finish you applied was Howards Butcher block conditioner, pictured here:
Olive oil is a decent finish for temporary cutting surfaces, but may turn rancid over time. It should also be noted that the butcher block conditioner should be applied repeatedly, at least once a month, in order to keep odor down and the wood well protected.
nice action shot, by the way. I like the knife in the picture, that way we all know what it is!
