Journal Content
Series Name
Box #3, doing the doors
Went through what was left over from the first 2 boxes..
Hmm, wide panel was not wide enough to make 2 doors with...but, if I rip it down the center, it can be the 2 sides of the box. Sorted through the narrow stuff...looking for enough to build the doors with..
A bit of trim here and there, work on a couple glue joints..
And glue up two blanks for the doors...and set them aside, for now..
A box needs 2 sides, and 2 "ends", so..
2 ends..one had issues, could not get it flat on both faces...until it was way too thin...so...
A kerf cut all the way around, wanted to match the thickness of the other boards I was working with...connect the kerfs..
Results?
one on the left..
Needed to match this board for thickness. Ripped the wide panel down..needed to rip again to get both the same width..and then joint the saw marks away..and match up the 2 end pieces to the sides for width...
One of the sides needed a little work..
To get it flat..we have ways..
Let the 4 sides sit a spell...as I need to work on the doors a bit more...then I can cut the sides and ends to final length...
Stay tuned...
Results?
one on the left..
Stay tuned...
