Project Information
I helped my sister-in-law, Janice, build this little camp trailer to tow behind her Subura. She bought a set of plans but we only used the pattern for the side profile.The rest is our design. Overall size is 4'x4'x8'. The frame is a folding trailer from Harbor Freight, modified and stiffened. The sides are made using one sheet of 3/4" ply for the inner core and another for the outer core. The inner core is notched for sliding dovetails on the cross ribs. This aligns everything and locks it together side to side tight as a drum. The cutout on the sides are to accept 3/4" rigid foam insulation and the top gets 1.5" insulation. This little guy is very quiet when your inside and stays warm from body heat. The top and sides are covered with 1/4" ply and then aluminum sheeting.
The sleeping area is about 45" wide x 71" long, and has an overhead shelf for books etc, and two more over the footwell for clothing. The back lifts up and is called the galley.There is a pullout rack for a cooler, a place for a camp stove, and plenty of storage for all your kit. No electric lighting, no sink, no toilet, no real stove. Very basic, but complete and cozy. Total weight is about 800# lbs and tongue weight is about 120#lbs. You have to keep looking in your mirrors to make sure its still following you.The sweet thing is when you get to your campsite,one person can lift the tongue and wheel it into position. We crowd these together at campsites…because we can.
Cool factor:
In Oregon you dont have to license these as long as they dont have a fixed stove, they are considered a utility trailer.
Gallery
Comments
· Registered
An outstanding job. Makes me want to go and camp out. (I still use my 1967 Apache pop-up, though it needs work.)
Not to be nosy but about how many American dollars? (I need to replace that Apache pop-up)
Where did you find the aluminum that wide?
· Registered
Pretty cool. I'm almost too claustrophobic to look at the picture, but cool nonetheless.
· Registered
A very nice low budget camper. A very nice crafty project.
· Registered
Now that's the way to go - keep it simple! I quit camping several years ago, because it was just too much work to load everything you needed into the car. This looks like the right approach to me - hook up the trailer with everything already in it and go.
Nice job constructing this useful project.
· Registered
Now Andy, that's a BIG box. Pretty neat.
· Registered
Don will love it - a box on wheels! Nice job.
· Registered
WOW, you did a great job, I have been wanting to build one of this for sometime now, just can find a the right trailer,(cheap) might have to look into Harbor Freight. Thanks for sharing…..Joey
· Registered
Thanks all.
@PanamaJack-The cost on this was about $1100.00.But my wife and I built one for ourselves that is 5' wide x 4' high and 10'long,that has a Queen size mattress and we only have about $800.00 into it.The aluminum sheets are fairly easy to get thru any sheetmetal fabrication company and runs about $60.00 for a 4×8.
@Tom-I dont like confined spaces either,but this isnt a problem for me.When lieing down,my shoulder is at the door opening and my hand is just below the handle.Its easy to bend my knees and pivot thru the opening in one fluid motion if the need arises. :)
@Joey-We salvaged a camptrailer (free)and gutted it for the frame and axle.This is the best way to go,if possible.Make sure and crawl under and take measurements, etc… first.We tried a tent trailer,but the frame needed to be completely cut apart and rewelded to work,so it wasnt worth it.Another advantage of using a regular trailer frame is that they typically have 14" or 15" wheels which look more retro.
· Registered
There is a guy here in town that makes them. They run about $8,000. Seems kind of high to me.
· Registered
What a delight!
· Registered
Andy -
I have looked at the teadrop site in the past. These are very cool little trailers wih almost a cult following. You did an awesome job!
David
· Registered
Nice job Andy….I didn't build mine …but we love our Cozy Crusier.
· Registered
DW and I love teardrops. I have one as a project in the future. An excellent and low cost way to camp out.
· Registered
Wow! Does this every bring back memories. When a lad I did a lot of camping with my family. We could only afford tents. The Tear Drop Trailer was only a distant dream.
Almost persuaded to give it a go.
· Registered
Great looking trailer. I've done a little campling in my time but I now like full size beds.
· Registered
Jeepers, I coud pull that with my TR3.
· Registered
I have wanted to build one of these for a long time. I went to see my brother race over labor day at Lime Rock Park. He has an airstream that he converted to a moving garage/living space that he used for his all aluminum tour . I saw a teardrop trailer being towed by one of the micro fiats. Very nice little setup. He had storage space built into every conceivable spot. Great project.
· Registered
Definitely need to get some plans. HHmmm….actually this would be a great Sketchup project design.
