Project Information
After the emabarrassment I felt from putting a half-baked project on the site I decided to tear out the cabinets and build carcus' so that the drawers moved smoothly and the cabinet was more stabile. I will be putting the formica in this week after I finish the upper cabinet. I learned my lessons from the lower cabinets; just build square carcuses and shim where needed. Thanks for making me do better work.
Yes, the pole is going to be replaced with gas struts. I use it now because with my little brain I can only work with 14 projects at one time :) I have added a few pictures so that I can better illustrate what I am working with.
Gallery
Comments
MUCH better… Now for the $64,000.00 question as it were…
What's with the metal pole? Does it move out of the way so you can open the drawers?
Definetly would like see to the finished product. It looks like it has alot of room to work with.
Is this a trailer
The drawers look like they line up a lot better. Glad you took the time to square up the frame work. It's really looking good. Keep up the good work.
