Project Information
The Meeting (Quaker church) I attend has a woven basket that's been used for years to hold tea bags during coffee hour. During my month to set up coffee I noticed that the basket was on it's last legs - one of the corners was broken. Being the industrious woodworker that I am, I decided to do something about it, and this is the result.
It's walnut with a plywood bottom, all pieces were scrap. The sides are 3/8 inches thick, 1 1/2 inches high. The external dimensions are 13 1/2 X 6 1/2. The divider is 1/4" thick.
The corners are rabbeted, and the divider sits in a dado at each end. What you can't see from these carefully staged pictures is that I had to add shims to the dividers - the dado ended up a little too wide.
The finish is a gel stain to even out the color, topped by a spray polyurethane. The spray poly was chosen for ease of application, though if I had it to do again I would probably make a different choice.
Gallery
Comments
· Registered
This one will last forever.
· Registered
Looks Good!
I like the idea. I could use something like that at my house. Maybe just a little smaller.
· Registered
Hey chelle
Nice thought I'm sure your church will really appreciate your super work for some time to come. it looks great.
· Registered
your grandpaw should have known better !
you seem to enjoy your work ,
it realy shows ,
congratulations !
