Project Information
Since the expiry date of my old tapering jig has exceeded, I decided to fabricate this new model that also allows to joint at the table saw or at the router table.
The parallel base is a 9" X 28" piece of 5/8" MDF on which I laid out parallel lines for five sets of 3-1/2" long 1/4" carriage bolts. The two hardwood pieces (poplar) about 5/8" X 1-1/2" X 8-3/4" act as pressure bars.
The small lower knobs are only used to level the pressure bars. The securing down pressure is applied with the larger top mounted knobs.
For repetitive cuts I'm adding a stop strip for now (photo #1), until I fabricate sliding stops to be located between the pressure bars.
To straighten edges, the same jig can also be used free hand at a router table outfitted with a
bottom bearing mounted flush trim bit or a guide bushing.
Thanks for looking.
Find all construction details and more photos on this page of my blog.
Best,
Serge
http://atelierdubricoleur.wordpress.com
Gallery
Comments
I like the hold downs. Wondering if it could use adjustable stops to secure the piece from the side?
Great Idea. Nice and simple design. Looks very flexible. I like it. I think I'll make one in the future even though i have a commercially build one.
Thanks for sharing.
very nice one Serge, I have one similar and it's perfect when needed. Very well done
Great idea beats the snot out of the cheap aluminum jigs.
Great looking jig Serge, thanks for sharing.
you grew a beard !
Very nice tapering jig…simple yet very effective design….like it a lot, well done.
Thank you, guys for your comments. I'm glad I built it and it should be useful for many years to come.
@SteveW: Eagle eye. I only changed my gravatar yesterday! The last time I shaved was in January. I rather be building jigs than shaving! :)
@DocSavage45: Be patient, Thomas, because I'm thinking about adding sliding stops between the pressure bars.
@steliart: I did see yours and was inspired by it as well as some LJ's models. One can find great stuff on LJ. Addictive as they say!
Best,
Serge
Great design!
