Project Information
Here is my completed Battleshots / Beer Pong set. I have been wanting to make a Battleshots set for a while but when I saw a similar design, knew a multi-purpose portable table would be ideal for the man cave, parties, and of course hauling to Tuscaloosa for a little tailgating. I went with poplar boards for the frame, cabinet grade birch for the tops and bottom. For the scoring grid, used the chalkboard paint, works great!
Those are window locks for the top panels and the folding legs can be purchased from Home Depot for $25. My vinyl cutter came in handy as well! All-in, I have about $95 in supplies (counting vinyl and everything.) If you had to pay someone for the decals, then add about $65.
Thanks for looking and hope you like it.
Roll Tide!
PC
Gallery
Comments
· Registered
Farraha97 - I don't have any formal plans for the main table part, I pretty much designed as I went. I do have some plans, templates that I made for the ships, which were all cut out of 1' poplar. I also have the vector file I made for my vinyl cutter. Would be glad to send to you if you are interested. Just shoot me your email.
· Registered
The pictures are great. Very cool idea. Great craftsmanship. The overall size appears to be a full 4×8 sheet of plywood or a standard folding table? No problems with the vinyl staying attached to the chalk paint?
· Registered
Where did you find the svg files you used for the vinyl cuts? They're awesome!
· Registered
LOADDMA - Thanks for the post. It did take nearly a full sheet of plywood for the tops and bottom. No issue with good vinyl sticking to any surface. I use the Oracal 651 grade vinyl, hit it with a little heat and it will stick to anything!
· Registered
how do I order one?
Roll Tide!
PC
- cobb769
