Project Information
Made theses jigs up last week. love the table sled, right side is within 001 square using 5 way square check. Still working on left side. The angle jig was wonderful while building a new 3-D cutting board, which I'll post tomorrow. The stops really speed things along. The M/T jig allows you to cut a tendon with a table saw and the jig is adjustable with 1/4 -20 bolts. John W. Nixon credit for design.
Gallery
Comments
Nice jigs, reminds me I need to start updating my jigs
Looks good. I need to make one like this. Did you shed blood when making it? (pic 6)
"allows you to cut a tendon with a table saw" NO NO NO keep those tendons away from the table saw ;-)
Now that's a serious table sled, nice build Edward Pickney!
Now that IS a sled! Great job.
I will make a sled like that someday. I'm just setting up shop & need to build lots of shop projects, ie; jigs, shelves, storage, etc…...
I will probably start with a "Down & Dirty" sled and then once the shop has evolved, build me a "Moster Super Sled".
Thanks for sharing & the motivation!!!
Pretty Sweet Sled Edward…..
Looks like the bells and whistles are all there. Great job.
JCantin,
I met vertical tendon, much smoother. and yes, I have to tattoo most of my projects with a little blood. Its in the book!
Boy Ed you have been a very busy guy ,all those jigs are great.
Nice set of jigs to go with the sled. Some really good ideas here.
This one has all the bells and whistles. Good job!
Now this is a sled I really like. Hope you don't mind if I copy it.
Would you explain what the 5 way square check is and how you did it???? Nice sled.
In Loving Memory
A very useful set of jigs and they look very well thought out and made.
I used a good piece of 3/4" plywood approx. 20"x20" With the straight edge against the fence and back of the sled. Cut about 1/2" off each side going clockwise. When you get to the 5th cut, measure the distance at the top and bottom of the 1/2 scrap. The difference between the top and bottom of the scrap will tell you how much your off. Here's a link that will explain better http://www.newwoodworker.com/basic/5cut.html
Nice sled. UHMW runners. Adjustable stops. Miter fence. Tenon jig. Hold down clamps. Great build.
One question, why is the left side out? and Right side good? Check that (<.001) GREAT!
Guess my jointing and planing not up to par. Either that or the fence moved on the left side as I tightened the screws. Either way left sides out about .01. I haven't messed with it for a few days, I'll take another look tomorrow.
