Project Information
At last, I've finally built a Super Sled. I used 3/4" ply for the base, UHMV plastic for the runners, and cherry with black walnut plugs for the fence, handle, rear support, miter attachments and miter attachment stop blocks. I opted to recess T-track into the rear fence for mounting a flip stop I picked up from Rockler. I still need to build an extension flip stop for the miter attachments but I'll leave that for when it's actually needed. For now I'll primarily be using the sled for cross cutting. In fact I already have when making the last set of cutting boards and it was a blast. I suspect between my new drill press table with fence and the cross cut sled I'll see my accuracy, repeatable, and overally safety go way up. Regarding safety, you'll notice I decided to push the sled all the way forward once so the saw went through the handle in the full raised position. While using the sled this should never occur, but in case I ever get distracted I'm hoping that slit in the back will keep my aware of the danger zone. So long as I use the actual handle I should be in excellent shape.
Gallery
Comments
· Registered
very impressive
· Registered
That is a sweet sled and on my to do list. Thanks for posting.
· Registered
great work, i made one of these myself and it works good i grab for it everytime i need to do cross cuts.
· Registered
Your probably not gonna take it off your table that much. I made one almost a year ago. It very seldom comes off the table. I have since made a tennoning jig and a spline jig. They both attach to the sled with the 1/4-20 knobs and bolts.
· Registered
If you guys keep coming up with all of this bigger and better stuff I am going to need a bigger shop.
· Registered
I actually do find I take it off quite a bit actually - to do rips. I find I'm ripping more than cross cutting, but cross cutting is still very important. If I can manage it I aim to build a french cleat system for hanging it up on the wall later today, we'll see.
· Registered
Wow!
Nice sled
· Registered
Hi Will, Great looking sled! I like the contrasting wood plugs in the screw holes - nice touch. It's great to have nice jigs that you can take pride in how they and operate. Well done.
John
· Registered
@routerisstillmyname: I considered attaching some short of shield over the top, as I've seen others do, but ultimately decided against it. While I use hold downs for cross cutting small pieces, I often find I simply setup a stop block, then hold a piece against the back fence while pushing it across the table. I feel like a shield might get in my way too much, either my hands for placing and removing the wood, so I've opted not to do that for now. I try to always watch where my hands are, keep them well out of the way, and worst case scenario I do have a brake on the blade to back me up! :)
· Registered
These sure come in handy. Nice build.
· Registered
this is a fine looking table saw sled… nicely built and multi-functional…
· Registered
Man o man!!!
· Registered
Definitely a Cadillac sled! I like the addition of the miter fences.
I just finished one of these for myself (I'll post it as soon as I get pictures), and wish I had done it sooner. You're gonna love it!
· Registered
Nicer sled than mine. On mine I put a large block where the saw runout occurs which keeps fingers above the level of the blade, and provides an additional heads-up when my hand gets to close to the blade track. Seems to work and very simple.
