Project Information
TENÍA ÉSTA MÁQUINA DE VARIAS FUNCIONES, DEL AÑO 1960 Ó 70 APROXIMADAMENTE: USABA LA SIERRA Y LA LIJADORA PERO LA RANURA DE LA GARLOPA ERA MUY PELIGROSA PARA TRABAJAR EN UNA SUPERFICIE LIMITADA.
DECIDÍ USAR LA SIERRA SOLAMENTE Y CONSTRUÍRLE UNA MESA ACORDE CON SU ANTIGUEDAD ;-)
TENGO UNA SIERRA DE MESA DE 1500 KW EN DONDE HAGO TODOS LOS CORTES, PERO ÉSTA SIERRA ME SERÁ DE MUCHA UTILIDAD PARA CORTES DE TABLAS PEQUEÑAS CUANDO HAGO JUGUETES ;-)
SU MOTOR ES DE 3/4 HP DE POTENCIA Y TRABAJA MUY BIEN EN PEQUEÑOS ESPESORES DE TABLAS ;-)
Gallery
Comments
THIS MACHINE HAD SEVERAL FUNCTIONS OF THE YEAR 1960 Or 70 APPROXIMATE MIND: USING THE SAW AND SANDER BUT SLOT WAS VERY DANGEROUS Jointer TO WORK IN A LIMITED AREA.
I decided to use build you ONLY AND SAW A TABLE IN LINE WITH YOUR OLD ;-)
I HAVE A TABLE SAW 1500 KW WHERE DO ALL CUTS, BUT SAW ME THIS WILL BE VERY USEFUL FOR CUTTING BOARDS TOYS SMALL WHEN I ;-)
IS YOUR ENGINE 3/4 HP POWER AND WORK VERY WELL IN SMALL THICKNESS OF TABLES;-)
very cool great job.
AKANDREW: 3/4 HP, BUT WALK BEAUTIFULLY ;-)
DEAR JIM THANKS!! SENDING YOU A HUG (._.)
buenole hecho vato
(estos locos aqui hablan raro
hablan parte y parte de dos lenguas)
it is good ese
se hace lo nesesario
quando se puede
cuidate bien
estate seguro
he hecho varios
entre los anos
con tabla (ply)
y seira skill
la base es importante
ponlo encima de un ply mas amplio
que no se tumba
(como el trabajo esta
todo por el lado)
qualquier que gana la loteria
un avion para conocernos
Looks like it works for you, and that's the important thing.
Nicely done.
Where there is a a will, there is a way!
Best thoughts,
Mads
Very resourceful, it looks like you get the most out of your tools.
Thanks for posting.
A handy tool that you will get many use from. GOOD JOB !
Very in genious! Necessity is the mother of invention. You made a useful tool out of what you had and should be very proud of it! Thanks for showing it!!
Very innovative! Great job of using your available resources. Looks like it will do a lot of woodworking tasks.
Muy bien hecho Kova! una buena adición a tu arsenal de herramientas, darle un mejor uso y nueva vida a una joya de años atrás.
Un fuerte abrazo!
It's good to have a table saw. The original machine looked pretty scary. Your fence and cross-cut guide designs are creative.
Es bueno tener una sierra de mesa. La máquina original se ve bastante aterrador. Su guía y de corte transversal diseños de guía son creativos.
¡El que la sigue la consigue!
Al final la has hecho, buen trabajo Quique.
Un abrazo
Without insulting you I just hope your project does not become a safety issue.For my money these saw tables can be bought from the Chinese so cheaply.or even pre-usedor second hand as we call them ,that I would not personally advocate going down this route but then maybe I am just being to much of a scaredy Cat.Please have safe fun my dear friend. Alistair
SCOTSMAN: NOT offend me, I UNDERSTAND THAT YOU HAVE THE GOOD INTENT TO CUT ME NOT A FINGER AND I THANK YOU!!!
TABLE-SAW WAS THE VERY SAFE BECAUSE COPY SYSTEMS BRINGING THE MARKET BUT I had more fun than buying ;-D
GRACIAS RAMÓN QUERIDO!!!!!! TE MANDO UN FUERTE ABRAZO!!!!!
