Project Information
I just built a new cross cut sled for my table saw, I had an old one but it was not as accurate as I need to build the jewelry chess. This time I used ½" Baltic plywood for the base with Maple for the front and rear fence. I went with 1/2 inch plywood so I wouldn't lose very much blade height capacity. I designed the sled with versatility in mind. I added four slots; these slots function the same as t-tracks but keep the top of the sled smooth. The four slots allow for the use of stop blocks, miter fence and other add-on jigs. I routed the hold down slots from the underside first with a ¼" spiral bit all the way through the board, then with a ½" to a depth of ¼" this so that I can accommodate ¼"- 20 bolts. I made some miter fences from ½" Baltic with Maple edges, and also put slots in them to incorporate the use of Toggle Clamps, hold downs.
I used the five cut method as described by William Ng in his video to get a sled dead on square. I also added a stop block/rip fence so that I can rip thin strips of wood for the trim on the jewelry chess. The stop block has a ¼" slot in it so that it can be adjusted. The saw blade protection block is solid Cherry.
Gallery
Comments
Sweet sled!
Very nice work Jake, looks excellent.
Very nice sled. Can not find the video.
Jeffrey
Nicely done. did you also make cheater setup blanks for commonly used angles? also fyi the video references is not available.
Great job
Nice, I made one just like it a few years ago. I love mine.
This sled you claim you designed is stolen….............by me! nice work
beautiful sled. I am waiting for my Metabo Table Saw. I may have to adopt your design and make a sled for my shop. thanks for sharing this.
Beautiful and functional… Great sled, thanks for sharing…
Very well done and looks like some nice joinery work too, have fun. Alistair
Very nice…. I need one bad, but…. well maybe someday…. lol
Terry, just build one already. It is that simple, and you will not regret it. You will most likely wonder why you took so long to decide that it was/is a good thing to have. ;-)
