Project Information
This is a project I have been wanted to do for a while but since I got a smaller hose that attaches to my ROS I kinda put it on the back burner. I decided to go ahead and do it. I used pine and some pegboard. I also used some thin paneling for the inside tapered bottoms. I tapered it all to the side hoping it will all go to the suction hole in side. Initially I plan to use it with my shop vac. I haven't used it yet but it sucked pretty good just throwing some dust up on it.
Gallery
Comments
Nice job. They work really well.
I too saved this to my favorites. Nice job.
Very cool idea, I might need to make a bigger one though for some of the larger projects!
great job. I just picked up some peg board to do the same thing. Great timing. What size did you make it? Would also like to hear how it works after you have had a chance to put it to the test.
In Loving Memory
It is 16"x24"x4". Hope this helps.
I have the rest of the pegboard which is 32×24 and have plans for a bigger one if this turns out to werk well. I may make it to fit my DC and use a 4"port. I would have to make it 6" high to accommodate the 4" port.
saved - would be interested in feedback in a few weeks. if it works it should really help keeping fines out of the air.
You can block off some of the holes with blocks of MDF to increase suction.
Another "must-do" project! :)
In Loving Memory
Thanks guys for the comments. Hope it werk good for those that build one. I'm not into projects right now that require this box but in the near future I have something in mind that I could use it on. I built it mainly for use with my belt sander as I have no DC port on it. It is an old craftsman 3x?. I use a small dust hose on my ROS which werks very well.
I was thinking of making something like this, but with a sliding panel under the peg board to block off the unused holes when the work piece is smaller. When sanding a solid piece of wood, only the holes just beyond the edge of the wood will really suck in the dust. Blocking off the others outside that border will increase suction, and will serve to really hold the piece down to the peg board. Anyone tried something like that?
If you exit out the bottom you don't have to make it 6" tall to accomodate a 4" hose.
Nice build.
In Loving Memory
Michael you are correct but then I couldn't put it on my werkbench.
Pete, Mr Ron mentioned something similar. Since I haven't actually used it yet that never occurred to me to do but it is something I will keep in mind once I use it. Thanks you guys for the heads up on this.
That's a handy accessory to have for sanding, was contemplating one for myself sometime. You have given me a few ideas. Thanks.
David
Thanks for the posting. I often sand small projects in the basement but it is frowned upon, if you know what I mean. This sawdust collector is definitely on my list.
