Project Information
Wood And Materials Used
ash and elm
I got some small ash logs from a friend's property about 18 months ago and finally got around to making this chair from it. The wood was still green enough to drawknife pretty easily.
I mostly followed the plan from Christopher Schwartz's book.
The seat is made from locally sourced white elm planks (not easy to find due to the Dutch elm disease). All the ash parts are split from the log and shaped by drawknife and spokeshave. I did reverse-tapered octagons on the legs and stretchers. I saddled the seat by hand - don't have an inshave or travisher, instead I use the Lee Valley chairshave. I've never worked with elm before, it was quite a bit more work then the white pine seat I saddled previously.
I tried to steambend the arm. Left it in the steam for over two hours, but I just wasn't strong enough to get such a thick piece to bend, I would have needed some kind of come-along. So I did a bent lamination instead. I steam-bent the laminations onto the form so that the laminating would go more easily.
I wish I could be more accurate with the leg angles. I can see that they're not consistent from one leg to the other. I think I get the original hole pretty close but then get off with the reaming. I may try a shallower angled, handheld reamer rather than the LV drill-powered one I used.
Comments
· Premium Member
Looks like an outstanding job on the project to me. Thanks for sharing,
· Registered
Looks great, just did my first drawknife chair and the reaming is tough!
really like how the wedge color pick up the grain of the seat.
· Registered
Great looking chair in my humble opinion. You should be proud!
· Registered
Nice job. I'm sure the leg angle is one of those things only the creator will see.
· Registered
Thanks for the kind comments everyone. It was a fun project. No tool is as much fun to use as a drawknife (on nice straight-grained green wood).
· Registered
Gorgeous. Heirloom quality. Looking forward to a stick chair class this summer.
· Registered
Great looking chair. Your attention to grain flow has payed off and the chair has an overall good balance. The legs issue you will get better next time. Thanks for sharing!
