Project Information
I needed a new stool for my shop. The one I mostly use is 18" high, which is too low for my new titanium knees (they'll get better), so I decided to make a new, taller stool.
I took a piece of 3 inch wide 4/4 maple that was just under six feet long, ripped it in half, then crosscut it in half, giving me four 1½ x 1 legs, about three feet long, but one had a knot in it, so I decided to make a three legged stool. Using a jig and my jackplane, I changed them from rectangles to octagons.
Meanwhile, I cut two 18" pieces off a 4/4×8 inch (one edge rough) elm board, planed up the edges using the jackplane, and glued them together. My aim was a 15×18 roundish seat for the stool. After some cutting with various saws, I finished rounding the seat with a spokeshave, and was amazed at how pretty the grain was. Chamfered the top edge ¼" in and down (so 45°︎) and the bottom edge ¼" down and 1" in using a spokeshave. Use the jackplane to smooth the top of the seat (I had a few toolmarks left, but for my first stool, it's not bad).
Drill three holes in the seat, eyeballing the angle on the first, but then using a bevel gauge to make them all the same. Taper the ends of the legs, and bore tapered holes. Apply some glue and bang them together, adding (walnut, for contrast) wedges to lock the legs in place. Saw off the bits of leg sticking through the seat and plane everything smooth. Say bad words when I had a little chatter with the plane which left marks behind just when I thought I was done.
Three coats of BLO and a coat of paste wax. Then finally cut the legs so the seat is level, and done! It sits pretty well, but I should have put the legs a little closer to the edge of the seat.
Gallery
Comments
· Premium Member
Thanks guys!
Ron, the legs are a little light for me, but I weigh 280#. I think they'd be fine if they were oak or rock maple, but they're one of the softer maples instead. I did make sure they're relatively straight grain, and I tossed out the one piece that wasn't, so they're fine if I don't twist or turn on the stool, but when I make my next one I'll probably use oak, and this one will get cut down shorter for my sweetie to use.
There was a TON of 4/4 and 5/4 red oak in the bargain bins last time I hit the lumber yard, so I'll probably be digging through that this weekend looking for potential legs.
· Registered
Hi Dave,
I was wondering how you got the tops of the stools round?
Very nice job
· Premium Member
I drew two circles of 15" diameter, with their centers 3" apart (making an oval 15" by 18") on the 15×18 board. Then I used a coping saw with a new blade to remove most of the waste outside the circles, followed by a spokeshave to cut down to the circles.
Also used a spokeshave to chamfer the edges once the seat was round. All hand-tools on this one. That may not be a traditional use of a spokeshave, but it works pretty well for me.
The spokeshave was a Kunz #53 adjustable mouth spokeshave. I really like it for working edges, as I can close the mouth down to avoid tear-out or chattering on tricky grain, and elm can be tricky grain.
· Registered
Nice work.
· Premium Member
Note, the legs in this weren't solid enough for my 280 pounds, and I ended up snapping one.
I revisited the project with much sturdier construction and have been very happy with the result.
