Project Information
This started last November as a project in a woodturning class at Annapolis Woodworks. I was not able to finish before the class ended. The grain in the wood looked pretty special, so I decided to hang onto it and finish it. Recently, I finally got around to working on it. It would not fit on my lathe at home, so I finished it up with an orbital sander and a lot of elbow grease.
Originally, I planned to have it sit flat on its base like a plate, but I decided I liked the way it looked sitting on the tenon that was still attached to the bottom. Rather than cutting off the tenon, I used it to connect a base that I turned out of a scrap piece of mahogany. Now it creates the illusion that it is hovering in the air.
I am glad I decided to finish it because I like the way it looks.
Gallery
Comments
· Registered
Wow! I turned out really nice. I agree, the tenon makes it appear to be floating, and the grain really pops.
· Registered
This is really special. I have some nice walnut i found that would have been great for a square plate like this. Unfortunately i already chopped it up into round blanks. I want to try a square turning now. They are very elegant. You have inspired me!
· Registered
I do like it a lot also, how did you cut the legs? Did you make a jig and use a router?
· Registered
Very elegant looking dish. The square winged style sets it off.
· Registered
The base was turned on the lathe. I cut a square block of mahogany and then fastened it to a glue block that fit into the lathe chuck. I then drilled a hole smaller than the tenon on the dish in the block and gradually turned the whole larger until I got a snug fit on the tenon. After shaping the top side of the base and sanding it, I reversed the block and used the hole to refasten to the chuck. Finally, I turned off the glue block and then turned the bottom. Below is a picture of that shows the base before it is attached to the tenon on the dish.
