Project Information
I used to spray my projects out doors but I was always annoyed by the wind/bugs/setup time. I finally became fed-up after spraying a painted project white and finding that a million bugs loved my project so much that they wanted to be a part of it forever!
The booth is quite simple. Its a 12' x 10' rectangular 2×4 frame suspended from the ceiling by threaded rods. The frame is suspended just below the garage door opener so that the opener is still completely functional.
Two sheets of plastic cover the booth. One goes from the floor and over and down from left to right, and one from front to back. This leaves a seam on each corner of the room that I simply tape-up when in use. I put a painter's drop cloth on the floor.
When not in use, I simply pull off the tape from the corners and roll each of the walls up with a piece of conduit and hang it from the frame.
Gallery
Comments
Nice but pictures are upside down. How do you exhaust fumes?
Yeah Man, That's something I want to do went I get my spray gun. You are right on the money!
I have a similar booth. A box made from PVC with your approach with the plastic. I leave the garage door open for ventilation and to provide additional light to see the spray. Not pretty but sufficiently functional. All disassembles.
- pjones46
Thanks, pictures are fixed. I have a box fan filter that fits in a notch in the plastic right in front of the garage door.
I have done something similar but more kludged together by using magnets to hang plastic from the garage door when it's open. I can't just close the door without taking the spray booth down, but it is a quicker and dirtier form of what you are doing.
Looks good, I've thought about a similar setup for mine and might have to finally do it as I have approximately 30 window sashes to paint this summer.
