Comments
· Registered
Good looking bowl. Next time, try some sanding sealer to fill in the "pock marks". After you've turned the piece, apply some sanding sealer and sand while still wet to form a slurry. When dry you should have filled your end grain pocks.
· Registered
I've used thin CA. Several applications. Allow to soak in.
· Registered
Thanks Bill and Lew, I like the 2 different approaches, Bill's is reactive and Lew's is preventative!
