Project Information
I recently wanted to try making a box with wooden hinges. This one is made from 1/2" Quarter Sawn Red Oak. The corners are finger joints made on a Leigh D4R with the F2 template. I tried making them with a jig on my router table but was not happy with the fit. The Leigh Jig with the variable guide bushing was much better. I also used the jig to cut the hinge. The variable bushing also made it easy to get the right fit between the two halves of the hinge.
The latch was a pair of strong magnets and the finish was shellac followed by several coats of wipe on poly.
I made the hinge from Red Oak and used Yonico Router bits to form the knuckle and the Hingecrafter to drill the holes in them. A brass rod was used for the hinge pin.
Gallery
Comments
Nice build.
The wooden hinges turned out great whichever jig you used. I like the proud dowels/posts you've used to attach the hinge to the box. The whole box is very cool.
thanks for sharing.
Jon
Premium Member
How long to make the hinges?
The actual hinges only a couple of hours BUT..
I spent a number of days learning on practice hinges.
I had to resaw wood to the right thickness. It took a bit of set up with trial and error to get the knuckles just right.
I spent a couple of days figuring out how to cut the fingers in the hinges. I tried the jig I had for my router table and was not happy and made scrap. Finally, with the Leigh jig I got it right.
Now, I had to learn to drill the holes in the hinge. I tried using my battery drills and had problems and broke a few hinges with a few nasty words. I ended up using a corded drill with much higher speed and worked better. I also got a 1/8" brad point drill and that worked better.
Anyway, I could make new ones in a day but part is getting set up. In fact I could turn out a batch in a day.
Lastly, I am not fast or try to be. It was interesting just to conquer this with working hinges.
Premium Member
a very cool looking little box love the hinge GREAT JOB :<))
Nice box. Those wooden hinges are pretty much a show in themselves.
