Project Information
This is a simple wooden planter made from offcuts of European Oak found laying around in my wooden garage doors workshop - it's a nice little thing to put together for yourself, or to give someone as a gift.
You might find it easy to figure out how it was made from the photos above - it's basically a simple frame with some boards for cladding. The boards are glued and screwed into the frame, and two boards are attached to make a base (as you can see in the 4th photograph).
The finished planter is sturdy enough to hold a good-sized plant, as you can see from the last photograph.
It's a good example of how to make sure you use every piece of wood left over in a workshop!
Gallery
Comments
Beautiful box, I hope it will fit some pretty plant.
Nice job, I like the fasteners you used, nice touch.
Looks great and solid. Like the look of the oak and the screws are great accents. Great job!
Did you use some kind of liner? If so, what kind? Looks great
