Project Information
Plenty of the smaller tissue boxes showing up here on the LJ, I though I'd give it a go with some scraps!
The bases are finger jointed walnut and white oak, the top is from my dwindling stash of apricot.
I had expected more contrast between the oak and walnut after finishing, oh well 8^)
It all started with a glued up slab of oak/walnut to resaw into the 1/2" thick box walls:
The top needed an oval opening, so I made a template from 1/4" masonite.
The opening began as an oval printed out from a drafting program, then tack-glued onto the masonite.
I drilled out the bulk of the hole then finished with a saber saw. A rasp was used for cleanup.
A few pieces of double sided tape holds the template to the work piece:
A pattern bit on the router table does the rest. I use a top/bottom (dual) bearing pattern bit so I can avoid the "uphill" cuts across the grain by only moving the bit a tiny amount.
The hole is rounded over with a rounder bit on both sides.
The top has a stepped edge to "lock" into the base for glue up.
Quick and simple!
Gallery
Comments
I like the design and the use of salvage woods.
Nicely done! Will make excellent small gifts.
Splint, these are nice looking. How did you attach the tops to the bases?
Very nice. Love the contrasting wood you selected. The apricot is really eye catching. That top is great - I need to make myself a template like that. What finish did you use?
Thanks guys!
Art, the top has a rabbet running around the edge (1/8" deep) and it is glued along the end grain.
BB1, The template is nice to have, once it's made, it'll last for a long time. The finish is "natural" Danish oil topped with Formbys low gloss wiping varnish.
It's all but simple. It has some very nice woodworking elements like fingerjoints. I like the angled edges of top lid.
