Showcase cover image for Simple Men's Valet
Project Information
I had a 2' board of 5/4 ipe left over from a small outdoor project that I didn't want to waste.
First I resawed the 5/4 ipe on the table saw to get a pair of book matched ~1/2" boards; then I cut to length for the long and short sides. I used my favorite joinery for these smaller projects - variable width, rabbeted finger joints cut on the table saw. It's not much different than the standard method of cutting fixed spacing joints; I just use appropriate width spacers to get the desired spacing. and then I cut a rabbet in one side; that allows me to add the bottom panel through all four sides without exposing the groove at any point.
The last feature includes a small internal divider made of some scrap cherry I salvaged from a neighbor's tree; I used a Dremel tool in the plunge router base to cut the stopped dado for the divider and then I cut stub tenons on the cherry to fit the dado. The Dremel tool did not do well with the ipe….which meant of course that I had a justification for getting a compact router set to do that type of cutting in the future.
I originally planned to use teak oil on this since I have had good results with that and ipe on a prior project, but once I sanded, I liked the smooth look of it so it is going to remain unfinished. Lastly, I added a simple stick on felt sheet onto the two sections of the bottom and that was it.
I noticed that I did have a problem with splintering and chipout with the ipe as I have had in the past. I tried to minimize it with blue tape and that did seem to improve my performance. I'll have to include that step for future projects.
Gallery
Comments
Very nice. Thanks for posting this. Considering all the stuff I have piled on my dresser, I need one of these myself.
nice work .Merry Christmas and a happy new year.
