Project Information
While browsing the pine stock at Menard's (my local big-box home center) I happened upon a nice stack of beetle kill pine. I picked through the pile and bought all the nicely colored stuff and waited for a project to come along. Shortly after that, the wife asked for a couple side tables for the screened in porch.
The tables are 22" tall from the floor, the top is 14" x 18" and made up of two wide pieces glued together with a few biscuits. The legs are a glue up of two straight grain strips so they ended up 1 1/2" square. I winged the taper on the legs with a new tapering jig I built. The apron is 3" and joined to the legs with pocket screws leaving a 1/4" reveal. The end apron pieces have a 3/16" slot cut in them for a set of four cleats that are screwed and glued to the underside of the top so it can expand and contract at will. These tables will be on a screened in porch so I'm expecting a lot of movement.
I did most of the sanding and eased the edges before assembly. Final sanding was to 220 on the top, 150 on the rest. Finish is a liberal coat of BLO (Boiled linseed oil) allowed to dry 24 hours then water based poly. I thought it was important to use the BLO to bring out the color and mellow the white of the pine before applying the poly which doesn't really do too much for the grain or color of any wood. Three coats on the base, five on the top with a little steel wool between the final coats. I installed a set of nylon tap-in feet to keep it up off the cement floor.
Gallery
Comments
Very nice Matt, keep up the great work.
Nice job. Simple and classy look.
I am surprised that they carried anything with that much color in it. Most of them won't.
WOW! Matt, that turned out nice. I never thought of using the beetle kill pine as a part of the furniture design. It turned out nicely. Good eye.
Looks great! Your home center must carry nicer stiff than mine!!
Must be nice. Red oak, SYP, and poplar is all we get. Love the look of that pine.
The grain is awesome-nice build with it.
I am assuming you got the pine at the west-side Menards? Last year I picked up an awesome curly maple 1X3 at the s. side Menards & made an anniversary frame that I should post.
Thanks for sharing.
Bill in MI.
