Project Information
TENGO UNA TABLESAW HOME-MADE: http://lumberjocks.com/projects/64114 CUYA HOJA NO SUBE, NI BAJA, NI SE INCLINA: ENTONCES ME VEO OBLIGADO A SUBIR, O BAJAR O INCLINAR LA PIEZA QUE VOY A CORTAR ;-D
CORTÉ UN PEDAZO DE PLYWOOD DE UN CARRETEL DE CABLE QUE ENCONTRÉ EN LA CALLE, Y LE PEGUÉ UN PEDAZO DE TIRANTE PARA PONER LA MANO Y SUJETAR LA PIEZA QUE VOY A CORTAR, EN ÉSTE CASO: DEBO HACER UNAS RANURAS EN LAS PATAS DE UNA MESA Y TUVE QUE HACER UN SOPORTE QUE ME AYUDE A SUBIR 8 MM. EL TIRANTE AL QUE DEBO RANURAR ;-D
ESPERO QUE LES INTERESE Ó DIGAN SUS OPINIONES Ó LO QUE SEA, GRACIAS ;-D
Gallery
Comments
Per Google translate…
"I HAVE A HOME-MADE tablesaw whose leaf does not rise, or low, or tilt: THEN I have to go up, or TILT DOWN OR PART THAT'LL CUT;-D
In this case: I DO slots in the legs of a table and I had to make a support HELP ME UP 8 MM. I NEED TO STRAP GROOVING;-D
I HOPE that interests them or say their opinions or ANYTHING THANKS;-D"
Kova
HA! I don't speak Spanish. However I do speak many of the "ancient" languages like COBOL, FORTRAN, Basic, HP Basic, C, C+, etc.
-Dave
GRACIAS WOODSTOCK!!!!! JUSTO ESTABA HACIENDO EL DOBLAJE AL INGLÉS, CUANDO TÚ ME GANASTE DE MANO
JAJAJAJAJAJAJAJAJAJAJAJAJAJAJA
GRACIAS DAVE, ERES MUY AMABLE ;-D
I HAVE A HOME-MADE tablesaw: whose leaf does not rise, or low, or tilt: THEN I have to go up, or TILT DOWN OR PART THAT'LL CUT ;-D
Cut a piece of plywood a spool of wire that was in the street, and hit A PIECE OF PLACING STRAP FASTENING PIECE HAND AND I WILL CUT, in this case: I DO IN grooves table legs And I had to make a support HELP ME uP 8 MM. I NEED TO STRAP GROOVING ;-D
I HOPE that interests them or say their opinions or ANYTHING THANKS ;-D
Hi, Kova!
Good intention.
Did you think about zero clearance ?
HOLA AMIGO ALEXEY:
MIRA EL ENLACE ADJUNTO ;-D
COMO CONSTRUÍ LA MESA SOBRE EL HIERRO DE LA ANTIGUA SIERRA,
ÉSTO NO ME PERMITE EL ESPACIO CERO ;-(
DE TODOS MODOS, PARA CAMBIAR LA HOJA, AFLOJO DOS TORNILLOS Y LISTO ;-)
TE MANDO UN ABRAZO Y GRACIAS POR MIRAR Y OPINAR!!!!!!!
hola kova
veramos si esto lo entiendes
dos bases
con cun(y)as entre ellos
al lado de los dos
una oreja fijo para que la primera camina contra la sierra
adelante y atras
pero no por el lado
la segunda ariba de la primera
hecho igual pero mas amplio
para capturar la primera
cun(y)as fijo ariba la primera
(un par cada lado la hoja
porque se va a cortar la base
quando se empuja para adelante)
las cunas al reves abajo la segunda
ariba los de abajo
caminando la segunda para adelante
sube la base
las orejas se trancan juntos
(con turnilos temporales o como puede)
la de ariba tiene estopes adelante
y atras fijos y a 90 grados a la hoja
y suficiente alto para no cortar
(como un 'sled' )
camina la de ariba a su altura
contra la hoja
y pone el trabajo con el estope de atras
y camina todo junto
para cortar
hay que hacer de ply delgado
para no perder mucho altura
la de abajo mas largo (long) que la de ariba
para que no se menea mucho
DAVID: GENIO!!!! ME ENCANTA Y LO ENTIENDO: AL IR Y VENIR ESOS TRIÁNGULOS, HACEN QUE LA ALTURA DE LA HOJA SE MODIFIQUE ;-D
VOS SABÉS QUE YO ESTABA PENSANDO EN UN SISTEMA COMO EN EL DE ÉSTA FOTO ;-)
GRACIAS MAESTRO Y TE MANDO UN ABRAZO ;-))))))))))
El McGyver de la carpintería eres tu Kova! Que bueno tambien el estilo que le pones a las cosas con curvas y pintura.
Lo que propone Patron también me parece una muy buena solucion. Lo piensas intentar?
esa sistema en la foto sirve bien
poner bisagra adelante
y levantat atras con tornyos o cun(y)as
y un 'sled' atrapado por los lados
y otro 'sled' con los lados como pagina de libro
que se levantan o bajan para hacer angulos
un pin cerca a el corte de la sierra
Kova, eso es un buen truco. Me alegro de que fueron capaces de encontrar una solución a la probelm.
Me gusta tu solución, tan creativo como siempre. En adelante te llamaré Leonardo
Jajajajajajajaja
huh?
HOY USÉ EL SUPLEMENTO PARA LO QUE FUÉ CONSTRUÍDO Y ANDUVO DE MARAVILLAS:
LO ÚNICO QUE SE PODRÍA CAMBIAR ES QUE SE ATORNILLE A LA VALLA PARA QUE YO NO TENGA QUE SUJETAR TODO
CON MI MANO YA QUE HICE VARIAS PASADAS ;-D
GRACIAS A MI HERMANO RAMÓN, PORQUE AMIGO YA NO ERES (ES MUY POCO) JAJAJAJAJAJAJAJAJAJAJAJAJA
GRACIAS DOUG POR INTERVENIR CON UN COMENTARIO TAN AMABLE ;-D
GRACIAS MAURICIO POR LO DE MC GYVER Y SÍ, LO QUE PROPONE DAVID ES UNA BRILLANTE IDEA
TOTALMENTE REALIZABLE POR MÍ ;-D
GRACIAS DAVID, YA ESTOY BUSCANDO LOS RETAZOS DE PLYWOOD PARA EL TRABAJITO JAJAJAJAJAJAJAJA
aqui esta un 'modelo' de la ultima que di
(de las bisagras)
para ajustir el angulo de cortes mas amplias
(como para las partes de una caja
o muebles de angulo)
( hay que trancar la piesa
que no se menea en el corte
y el triangulito que suelta quiere trancar
contra la hoja de siera - cuidado !
quitando las 'paginas'
se puede usar para cortar angulos de molduras
con una guia fijo de cabeza
y trancar all angulo nesesario
saludos
GRACIAS DAVID QUERIDO!!!!!!!!
ME HAS TIRADO BUENAS IDEAS COMO PARA UN AÑO JAJAJAJAJAJAJAJAJA
espero que algunos le sirva kova
el ano entrante
sera para otra maquina
y otros trabajos
SÍ DAVID, PERO NO TE OLVIDES DE QUE NO TIENES LETRA "Ñ" EN TU TECLADO Y ENTONCES
"ANO ENTRANTE", VIENE A SER "CULO ENTRANTE" JAJAJAJAJAJAJAJAJAJAJAJA
para eso tenemos
papel de lija
