Project Information
To get better accuracy when adjusting the height of my tablesaw blade and router bits (hand-held or router table mounted), here is the height gauge I designed and made to be used with my digital caliper.
Two 3/4'' MDF scraps, one 1/4'' carriage bolt, appropriate washer and wing nut, and finally two 2'' wood screws. The base is 4'' square and the upright is 3-1/2'' wide and 5'' long. To receive the caliper, the 1/8'' groove is made at the tablesaw using a standard 1/8'' thick blade. The corner of the upright has been cut so the gauge can be placed over the tool to be adjusted. After drilling the 1/4'' hole for the bolt, I made I relief cut with a hacksaw to be able to clamp/tighten the caliper in its groove.
In use, place the tip of the caliper on the tablesaw or the router table top or base plate, and zero out the digital caliper. Finally, raise the tip of the caliper to the desired height and adjust the blade or the router bit at this level.
More details and photos on my blog.
Best,
Serge
http://atelierdubricoleur.wordpress.com
Gallery
Comments
· Registered
Another very useful contribution to our collective pool of tools.
Thank you Serge.
· Registered
Brilliant!!! Now I have an excellent excuse to go out and get another tool. Thank you Sir Serge.
· Registered
FUNNY I JUST CAME BACK AND PICKED UP A BATTERY FOR MY CALIPER AND THIS IS JUST THE THING I
NEED
THANKS FOR THIS AND I MAY HAVE TO MAKE ONE TONIGHT
GREAT JOB SERGE !!!!!!!!!!!!!!!!!!!
BY THE WAY WHAT DOES BRICO STAND FOR?
I MADE A INDEX PLATE FROM A SAW BLADE STAMPED WITH BRICO
THANKS
KIEFER*
· Registered
Thank you all guys.
@kiefer: To answer your question, BRICO is part of the word BRICOLEUR, which means woodworker or DIY, and FLEUR stands for FLOWER. I'm an avid woodworker and gardener.
Thanks and good luck making yours. There's always room for one more, as they say!
Best,
Serge
· Registered
Hello Serge
Another beautiful tool
Another job for me with your permission of course !!!!!
Thanks for sharing
· Registered
Clever to use what you allready have.
Best thoughts,
Mads
