Project Information
I've been wanting a nice mallet to replace my old store bought one, so I finally built it. It's made from walnut and maple, my favorite wood combination. The head is made from 3 layers, with the middle maple layer made from 2 pieces cut at a 2 degree angle to form a tapered mortise. Both maple pieces have a 1 1/4" hole to accommodate steel BB's for added weight.
The maple handle has a wedged tenon, which combines with the tapered mortise for a very strong joint. The contours of the handle were shaped with a belt sander on my homemade jig which holds the sander perpendicular to a small shelf, and also a round-over bit in the router table. Followed of course with lots of sanding.
Since you are fellow woodworkers, I have to disclose 2 mistakes, and my remedies to fix them. The first is the middle maple layer in the head, which is slightly wider on the bottom than the top. Since I don't own a band saw in my small garage shop, I had to resaw a small piece on my table saw, and it apparently tilted slightly when ripping and I didn't notice it in time. I considered scrapping the head and starting over once I noticed the mistake after the head was glued up, but after some thought I decided to see if I could still make it work. Which I did by offsetting the tenon on the handle in order to center it.
The second mistake happened when I was rounding over the handle with the router. A large chunk chipped out on the end. Instead of tossing it and starting over, I decided to cut off the handle a bit and add a walnut accent on the end. Since it's an end grain joint, I strengthened it with a dowel.
Now I have a proper mallet, with a couple of reminders that all is not lost when mistakes are made.
Gallery
Comments
Well done mallet. I would have never seen the mistakes and still can't find them. Mallets may start out pretty but don't stay that way long. I wouldn't worry about small errors.
