Project Information
I recently misplaced (lost) my 7" torpedo level and wanted to make some sort of tool for a while now. I figured I'd give it shot and make one. I wasn't sure how it would turn out since I mostly made this up as I went along but I'm pleased with the results.
I used some scraps I had of bloodwood, white oak and I think mahogany. I bought a cheap $4 plastic level took it apart and got the 3 glass bubble tubes from it.
I used Karis level build (http://lumberjocks.com/projects/55836) as inspiration as well as her method of leveling the level by simply putting it on another level that I shimmed level. I set the tube with plaster of paris. I got a little plaster on the wood inside the side views and didn't get all of it off so you can see a little if you look close. For the top piece I used a thin piece of bloodwood I had laying around, chiseled out a place for it sit in and cut out a little window.
I wanted to make this a special piece because I feel that it is really the beginning of me really getting into woodworking. The way I did this was by using all hand tools (except for the wood that was planned down already). I ripped the oak by with a handsaw, planed it smooth and shaped the level all by hand. When shaping it I drew out the general shape I wanted, trimmed off the excess with a saw then gave it its final shape with my hand plane. I sanded it all smooth then finished it off with tung oil.
A few things I would do differently on the next one will be:
1)shaping the viewing holes in the sides wider and better
2)use a different color tube, maybe blue
3)put in rare earth magnets on the bottom
4)probably use a different finish, I would like more of a shine but wanted to try using tung oil
Thanks for looking and happy holidays everyone,
Mike
Gallery
Comments
Nice work Mike !
And happy holidays to you and yours as well.
Nothing like making your own tools. Good job Mike.
Cool project, I love shop made tools.
