I keep saying that I'm going to make one. How long did it take you? Mine won't be all that fancy (no sanding). Have you used it? Is it sturdy enough for heavy roughing cuts with a drawknife?
It actually didn't take that long. I think I spent more time trying to figure out the dimensions and making a jig to bore the leg holes. The entire piece was made from a single 2×12 x 8ft- except for the 3 dowel pegs turned from oak and the walnut wedges for the leg wedges. About a day and a half, in the shop, for actual construction.
It is a type of vice that was/is used to hold material- usually small logs- to remove the bark and then work down to the desired size. The finished pieces are used for chair legs, spindles, wheel spokes etc. The work is accomplished with draw knives and spoke shaves.
Very cool, Lew! One of these has been on my list (my looong list) of things to do. I'd like to make mine out of half of a 12 inch oak log, and carve out the seat with an angle grinder. A good friend of mine's dad has one of these that he milled out of a log, and it's awesome. Takes a couple guys to move it, he's on it a couple hours every day.
Very nice shaving horse! It's much more refined than the one my husband made but it's functional and he added a padded seat that can be moved forward and back since we are different heights. I use the horse to start my shafts and it's really an enjoyable tool as there's no noise and you can actually hear yourself think as you shave down your wood, as opposed to the noisy machines.
