Project Information
The more I get myself into hand tools, the more I feel the need of a dedicated sharpening station. So here it is. It can also serve as a small workbench. The top is 3" think, with a slab of black granite incorporated. The middle is a well for a water bucket. When it is in use for sharpening, the cover for the well can be removed, and an attachment to the well will enable the stone holder to sit tightly above the well. The granite slab provides a flat surface for any flattening jobs using sand papers. The last picture shows some of the waterstones that I am using. I have to say the coarse stones (Norton 220 and 1000) are painful to use, as they become out of flat very easily. But again it might be a problem of my sharpening skill. Fortunately those stones are used less often than the 4000 and 8000 stones. I am planning to use the glass tiles with some sand papers for the coarse grit work ongoing.
The station measures 21"(D)x36"(W)x34"(H). It is primarily made out of savaged wood of various species, mostly Poplar, Fir, Pine and Oak. It is finished with yellow shellac and poly.
I tried the station out a couple of days ago, and it is quite convenient to setup and quite comfortable to bring razor sharp edges to my plane blades and chisels.
