Comments
very nice vessel i lake the design great finish
branch
Again a beautiful piece. Well done.
So cool. Man I really need to get into turning. I'm missing out on all this fun.
Another Beautiful piece…
Awesome work…
Very COOL!
Thank you.
Gerry, beautiful project. I am in awe at the many , many segmented pieces that go into compiling the finished work.
Well done. The thing that always puzzles me with Segmented Turning is, how do you hollow out a piece that is not in a wide open bowl format?
Lovely finish and nice combination of timber.
Regards,
Cliff.
One of the advantages you have in segmented turning is that you are not dealing with a solid block of wood, so the piece can be turned, hollowed and assembled in stages. In this piece, the top third and bottom two-thirds were hollowed, sanded and finished separately (the top also had a faceplate and glue block on it). The two sections were then joined together on the lathe (I have a live center with 1" x 8tpi threads for a faceplate or chuck).
You could glue up the entire stack of rings and use a hollowing tool, but doing it in two sections, IMHO, is a lot easier and produces a better result.
Aha!! Thank you Gerry!!!! That sure makes sense…..I had visions of poking a long curved Chisel inside a narrow top opening and basically flying blind. Your advice is gratefully appreciated and will help me delve a little deeper into the mysteries of Segmented Wood Turning. Many Thanks.
Regards,
Cliff.
