Project Information
Another LONG OVERDUE project. I was starting to lose a lot of floor space along the back wall, so I couldn't put it off any longer. I looked at a hundred other bins before settling on this design. The two litter buckets on the left bottom are my burn bucket (for which my New Year's Resolution it is to be more aggressive in filling), and another bucket I can take over to my chop saw or set beside the table saw when I'm generating scrap.
The material is mostly 3/4" plywood and pine of various dimensions and quality. The back has a slot for sheet goods. The shelves are all slanted to prevent an avalanche. Once I cut one slanted support, I used the cutoff piece as a storyboard to copy the angle to the other upright piece and to get the proper angle on the other shelves. I used my Harbor Freight HVLP Spray Gun and painted it white for two reasons: 1. I had a gallon of cheap white paint going bad anyway and 2. So I could more easily see the pieces when I'm searching for something. I didn't use any glue on the entire thing, just drywall screws in case I want to change the configuration later. I used an old garage door handle on the right end to pull it out to access the sheet goods on the back. If you build one with a handle like this, be sure to put the handle a little lower so there's less chance of tipping it over if one of the wheels hits a scrap on the floor!
I began by building the sled with two pieces of pine as a floor and a skirt board to hide the wheels a little bit and give the upper portion an attachment surface. The castors are simple ball bearing rubber wheels without locks (which I also had on another cart I wasn't using). After the base was done, I put the two upright sides and top on, then squared it up by putting boards on the back. I pieced in the shelves without really planning ahead, but just using the scrap pieces I had. It was amazing how serendipitous the scrap pieces fit into place. It seemed that every board I picked up was the perfect length or width or both. I planned it to be just wide enough to fit in the spot and still have room for a wastebasket on the right side. I also wanted it low enough to access the electrical duplex on the wall.
