Project Information
After getting David Wakefield's book on patterns for animated wood toys, I am building the ones I find most interesting to me.
The Scented Skunk uses a cam driven by the back wheels to make the tail go up and down.
I used maple for the light colored wood and walnut for the dark colored wood.
This is a relatively simple animated toy to build. The only issue I had was an error in the pattern in the book. The geometry is wrong for the bottom of the two maple pieces on the outside of the tail. Because I had found errors in this book on a previous toy, I thought about how to check the tail movement before the laminated glue up, but I did not see how to check it. I was able to remove enough material with the Dremel 1/2" drum sander to make it work ok.
To see my Trials & Tribulations of building this project, see my woodworking web site.
Still pictures do not do these designs justice, you need to see and hear the model in action…….so I made a Youtube video:
I have some pretty green 1/4" macrame string on order to replace the plain Jane white string shown in the video.
The little ones in the family should really enjoy playing with this one!
Thanks
Gallery
Comments
· Registered
another interesting toy, took me abit to figure that one out.
· Registered
- bushmaster
I was hoping my how it works picture would help explain how the cam drives the tail.
Thanks
Dale
· Registered
Very cool.
· Registered
Way cool project and would be a blast to build.
