Project Information
I always try to make some Christmas presents in the shop so I knocked out cheese slicers for the four kids and one for the wife unit. They are all kind of a variation of a theme, and from the same piece of cherry, so this is kind of cosmic. And they were fun to build. They are about 5 3/4 inches by 9 inches and 7/8 inches thick.
I found the mechanisms on the web at CheeseSlicing.com. They are about $5 a pop. You can get them in chrome or black. They were nice to deal with and even offer deals for multiple purchases.
http://www.cheeseslicing.com/site/681068/page/924433
I needed to make some jigs to make the boards. First was a circle (semi-circle?) jig for the bandsaw. I used the miter gauge slot to hold the jig in place. I glued a fence to the pivot arm and clamped the pieces to it. The pivot point is about 16 inches from the blade and I think this gave a nice gentle curve. I kept track of pieces so I could reassemble them to get matching grain. I spent some time creating a matching sanding block, but found that I was able to do nice glue-ups without sanding any of the curves. Straight from the bandsaw to the clamps. I did the surface leveling after the glue dried with a thickness sander.
These boards need a 1/4 inch hole drilled into the rear corner. This is 3 inches deep, so I used a jig clamped to the drill press to keep everything vertical and true.
They also need a groove cut into them for the wire. This groove is about 3/16 inches wide. It goes almost all the way through at the rear of the board (so the wire can wrap around the handle) and just 1/8 inch deep at the front. I settled on about a 5 degree angle and used a sliding table on the bandsaw. I placed a scrap stick behind the board at the bottom to create this angle. The groove is 2 1/2 inches from the end. I clamped a stop block to be able to repeat this. I found that I needed about two saw curfs to create a good groove width.
They were sanded to 220 grit, coated with sanding sealer, and then oiled. I plan to add a couple more coats of oil, and silicon sticky feet before they go under the tree.
Steve
Gallery
Comments
Really Neat idea. Hope you don't mind if I copy this!
Premium Member
Great idea, i like it ;-))
what part did you order? they all say replacement handle or cutting wire.
Ok Cheeze for the Holidays:)) cool boards
I ordered the Black Replacement Handle Arm Assembly, Item Number PPR-101AB. But it looks like the chrome one, or the chrome arm and black handle would be the same dimensions (?).
Another little trick that I used for finishing was to stick a six inch dowel into the drill hole. Kind of like a Popsicle. Then I was able to clamp these into a vise during drying, allowing me to finish all sides at once. It looked pretty silly with all five of them sticking up around the shop. I only have four vises, so I even clamped one upside down into the drill chuck.
Steve
Awesome project… Always looking for stocking stuffers.
Very cool gift! I like it! I have a box of exotic wood given to me with pieces around 16 - 24 inches long it ould be perfect.
Thank you for all of the great pictures and links that you've provided , Steve !
Those are some very artistic cheese slicers…....did you have any problems getting the feet to stick after oiling the boards ?
Feet stick? I don't know, I just make 'em and give 'em away. I suppose I should use something other than silicon sticky feet, but they are easy and grab the counter so well. I do clean the corners of the boards with mineral spirits before applying. They do seem to stick when they leave the shop.
Steve
I've always used the rubber feet that get screwed onto the board , replacing the standard screws with Stainless Steel ones , to prevent rusting if someone does not dry their board properly. Maybe next time I will give your style a try : ) Thanks for the feedback .
Great explanation and pics. While reading this I was surprised on how much thoought went into this. Great work and should help all of us who chose to make them. Thanks Spalm good to see your work again!
i just want to warn people and tell them these parts are for a right handed cheese slicer… not a lefty. I learned the hard way last night :p
What a gr8 way to cut the cheese. Very nice and gooda
