Project Information
I made these sanding blocks from some small pieces of lumber. They have Purpleheart base with Chechen on the sides and Goncalo Alves for the top. The dimensions are for 1/4 sheet sandpaper. I glued some 1/16" cork on the bottom to give a little softer sanding feel.
I wanted to use brass hardware but I was unable to find any when I was making them so I used stainless steel instead. I basicly glued up a 20" long piece of Purpleheart that was 5/8" thick and 2 1/4" wide and I glued Chechen that was 1/4" thick and 3/4" wide on each side. The Goncalo Alves was 5/4 thick and 2 1/8" wide. I drilled 1/4" hole through all of the pieces and used a dowell to hold them as I cut them on the chop saw at 4 1/4" long. This allows the 4 1/2" paper to overhang the ends a little to assist in sanding inside curves.
The plan or these sanders were from a Wood magazine called WoodExtra in a failed attempt at an electronic magazine. I signed up for 1 year (6 issues) and maybe got 3 before the project was canceled.
They are also in a Wood magazine book of small projects. I have the book but it is in hiding somewhere, so I don't have the exact name. Found it Wood Magazines Best Ever Woodworking Jigs, Homemade tools and shop Organizers. 2006 The label says display until Sept 12, 2006.
Gallery
Comments
Very nice work, and a useful project, Karson. Perhaps this help with the brass hardware in the future.
I build three of these sanding blocks in 1987 they were in one of Wood's first issues, I still have one of them the other two mystery disappeared. they work great, and look great, I mean meaning to make me a few more this winter when I have some time. Thanks for reminder. Joey
Karson, those are cool. Great to have around the shop and great use of small pieces!
I use them all the time with different grits in each of the pads. I found that the foam rubber ones that you can buy don't give you a crisp edge. Where these do.
If you want to soften the edge then the rubber blocks might be a better choice.
And Don on your comments on the brass hardware. Thanks. I was looking for brass wing nuts and I've not yet found them.
Revisited my favorites looking for scrap projects. Karson, McMaster-Carr has brass wing nuts. Woodcraft has brass T-bolts.
I'm going to hold a workshop on making these for our woodworking club in a month or so.
