Project Information
Just finished this sample tray… to be used for samples of organic yoghurt at the Rocklea Markets…
Each of the 4 recesses [ routed using my CNC router] holds 9 small plastic cups with various yoghurts…
And it comes with small signs… laser engraved with each variety of yoghurt…
Placed in a hole in the main board… or flat stacked for transport…
Tray is Camphor Laurel and the signs are Scented Maple…
Size is 330 mm square…
Gallery
Comments
· Registered
oh how fancy are we getting now….oh scented maple….oh la la….well i have a tray that holds all natural ice cream, the first two are rocky road walnut and butter pecan…so…how do you like them cookies…:)...oh and it was made using my H and H plunge router…..:)
· Registered
great looking tray. love the wood selections, they sound delicious ;-)
· Registered
Really nice design. You are thinking outside the box with these great products. Good to see business is going well.
· Registered
Grizz I like them cookies… but alas I am not able to eat them…
Roger et al thanks for the kind comments…
· Registered
Goose, please don't get mad, but please explain to me how this is woodworking?
· Registered
Looks GOOD to me…
Will satisfy the Need… that's what counts…
COOL work… as usual…
· Registered
I sent this as a PM but I think I want to post it here too….
I should not have to justify what I do… but to please you and no I am not mad….
I took some rough stock and jointed it, both face and edge, thicknessed it, I ripped it on my table saw, and crosscut to size…. then i took it to the router table and edge profiled the board with a round over bit…
Then and only then did I cut the recesses on my CNC…. could have used a template and router… but I have a CNC
It was then sanded using a drum sander and a ROS…. and the edges hand sanded….
The signs started out the same way as rough stock… went through all the woodworking processes of dressing…then laser engraved the words…could have used a pyrography burner but I have a Laser….. the posts were cut square on my bandsaw and glued to the sign…. holes were drilled using a drill press….ends of posts were rounded on the disc sander to fit in the round holes..
I then hand rubbed the tray with Danish Oil Finish and the signs were sprayed with Poly…
PS all the parts are solid wood….
Tools used….
Jointer,
Thicknesser,
Table Saw,
Router Table,
Band Saw,
Random Orbital Sander,
Drum Sander,
Sanding block,
CNC router,
Sliding compound mitre saw,
Drill press,
Disc sander,
Laser engraver,
What part of the above is not wood working and why....
· Registered
Very nice trays, Larry. I have a milling machine and would do some of those plunge cuts with my mill for ease of machining, too!! Mine would just be HNC machining!!.............Nice going….............Jim
· Registered
I see you printed the reply, thank you! You are a gentleman as well.
· Registered
Well that lumber didn't grow that way!!! Larry is it me or is camphor laurel a species of mahogany??
· In Loving Memory
Looks great Larry. It seems that there are end of applications for that lazer engraver. A pun not a misspelling!
· Registered
Larry it looks great! I love the idea of the signs, and they can always be switched out, too which is nice (if they ever change flavors of yogurts). did you happen to make any extra blank signs?
on a separate note, IMO - When people question integration of computer controlled devices, they tend to expose some jealousy on their behalf, and ignorance at the possibilities they contain. CNC's and Engravers are just TOOLS- its the person behind the computer that does the work.
Jealousy is a NASTY Cologne, and you can always tell when someone is wearing it!
· Registered
i love these pieces. The variety of work is a true reflection of your art. Keep posting!
