Comments
Beautiful wood colour combination and simple straight design.
Nice Job!. For some reason the photos make your shakers look gigantic 8^)
I'm thinking they would go perfectly with a napkin older base…..
What diameter of holes did you drill for the shaker ends?
Thanks Splintergroup!
I agree.. maybe a tray to sit in with napkins in the middle would be cool.
Holes are 1/16th I drilled all the way through for 9 holes on the pepper, but only 5 holes through on salt because it flows faster. other holes are half depth. Inner cavity is 1/12 inch diameter hole inside a 2×2 by 3.5 body.
I m thinking they would go perfectly with a napkin older base…..
- splintergroup
Correction.. height is almost 4" with the top and bottom. Center section was about 3.5"
