Project Information
I built this router table probably about 10 years ago, but I've been tweaking it and making it better ever since. It's not terribly beautiful, just some pine plywood for the carcass and doors/drawer. But, it sure works great for me.
I have two different inserts (both from Wood Peckers, they are very good quality) so I can easily drop in a different router. The fence is home made also, and the faces are adjustable, so its easy to rout a variety of different things. I added a big 4" dust collection port to it recently and drilled a couple of holes with "door" over them (second picture). Funny as it sounds, the box is so tight, I actually have to open up the door so some air can flow thru the box and improve the dust collection. It all depends on how large of a bit I've got and what task I'm doing. As you can see also, I have a hose that comes around the back to collect dust from the top thru the fence too. Finally, I have to admit that the miter gauge slot is cool, but I'm pretty sure that I've only used it once or twice to fasten in a feather board. And I could have just used a clamp to do the same thing. So, if you ever want to skip the whole miter slot, go right ahead. It's not a table saw!!
