Project Information
This is my router/tablesaw extension.
The frame is 1×3 poplar.
The top is 3/4" ply (to allow for the track)
The frame was rabbet (3/4"x1/4") to allow the ply to sit flush and then the laminate was applied over the top and beveled at 22 1/2 degrees (just makes a cleaner presentation)
I made the extension extra long so I can still cut up to 48" or so on the table saw without having to mess with the router setup.
The on/off switch is set flush with the frame so I won't hang up on it as I move by, but it still allows for easy and convenient shut-off.
BTW…
The blue track was cut off shortly after the picts were taken. It was never meant to be that long. I just posted the picts before it was cut.
Gallery
Comments
· Registered
looks real nice , after i clean up the shop , i think i will start addresing the router world better .
thanks for the reminder .
enjoy .
p.s. is that a seperate fence , or did it come with the riser setup ?
· Registered
Great Looking Setup!!
Have you had any trouble with the extended miter track?
· Registered
That looks like my Jessem Xacta router lift that came with my JET cabinet saw. However , your table is certainly of higher quality and I like the added track. My lift is facing in the opposite direction , so there is no room to install the track .
· Registered
patron - the fence on the lift came with it, it's ok but eventually I'll build a much better one. The long (white) fence is the table saw fence
lew - there is no purpose for the track to be that long. I just haven't taken the time to cut it off yet.
Dusty56 - the lift is a Jessem (problably the same as on your saw) I specifically installed it backwards so I could have the track. You should be able to just turn yours around and get the same result. NOTE: if you do….you will have to re-tap the screw holes for the fence because once the lift is turned around, they are on the feed side of the bit.
· Registered
that is a great looking router table… i did the same thing as you did…however i did it without the insert….now that i have a stand alone shop ( i dont have to share it with the wife's car) i think i will make it more permanent set up like the one you have…..hope you don't mind me borrowing a few of your ideas.
· Registered
I'm not going to mess around with it because I already have another router table with the track in it : ) Thanks for the feedback !
· Registered
Hey Screwge
Great router table . makes me what another one and I already have three . I'm a sick man. thanks for sharing a cool router table.
· Registered
Screwge, Thanks for posting this project. I have been contemplating this very thing for my Delta contractors saw. The undertable shoots were specially helpful Jim
· Registered
screwge:
I made this a favorite. I bought another router today for a TS wing installation. Your work will be instructive for my project.
thanks for posting.
· Registered
Great looking table and very versatile. I like where you mounted the switch. Good job.
· Registered
CanalboatJim
Bureaucrat
If there is any other input you need just let me know
· In Loving Memory
Great addition to the shop Terry.
· Registered
Screwge,
Thanks for posting your Router Table Table Saw Extension project . . .Nice Job!
As others have commented, your project has re-kindled my thoughts about getting this going, myself.
· Registered
Miter saw with a junk blade will trim that miter track to size, a blue sharpie will come pretty darn close to right on for getting the color right…
FWIW, I am planning on redoing mine, and might just edge mine as you have done yours. Sure looks good that way…
· Registered
Screwge, good simple functional design. Your router table is very similar to what I am making-for the 4th time. I have the same PC 890 router and will use the Jessem FX router lift for this build. The way you extended the track beyond the table is asking for trouble. I know I would walk into it within 5 minutes.
I just finished making the fence for my new router table. It's different from what I have seen here in LJs. The fence has a screw adjustment so it can easily make fine adjustments. The design is very simple, inexpensive and pratical. I will post it when it's finished. You may want to look into this feature when I post it.
· Registered
TheHarr
The track was cut off shortly after the pictures were taken. It was never meant to be that way permanently; I just jumped the gun on taking the photos so I could post it.
I guess I should take a new photo. It seems to get alot of folks concerned.
· Registered
Looks like I will follow in your footsteps. Any regrets on mounting your router in table saw wing? I love the idea of space saving…but would hate for it to get in the way.
-Steve
· Premium Member
Love the extended extension! Great idea.
