Project Information
here are some pics of the roubo bench I built. I made it out 2×6. Added some dog holes and hold fast holes. The holdfast are the gramercy ones. Let me know what you guys think good or bad. I did take some short cuts on some of the joinery. But if ask questions and comments. Thanks for checking it out.
Gallery
Comments
thank you. yea it weighs a ton.
sorry about the pictures not being right
- tigerwoodsman
Yea, I was going to ask, how did you mount it to the wall?
On a serious note, how did you join the top to the legs? It almost looks like dowels or pins like in drawboarding. And what are the overall too dimensions?
i used 8 inch structural screws. but first i used a forstner bit and went down about an inch. put the screws in and covered up with oak dowels. used a flush cut saw to get them down. then more planing and sanding. i know the actual way is used the dovetail with the through tenon. but i tried this way and actually really strong. but i know i will get some grief on the joinery on the bench.
another note that is the second jaw i made for the vise. the vise did not come with a template so i ended up screwing up the first one second is fine though.
- tigerwoodsman
I actually like the look of the dowels in the top. I am just beginning to plan my next workbench and I'm contemplating using wedged dowel tenons to attach the base to the top because I like the contrast of the dark dowels with the lighter wood. How about a couple of pics of the base? I'm just curious about the rest of the bench.
Welcome to LJs!
How do you feel about that vise on the 5" top now that you've worked with it? Any deflection to speak of at the top?
