Project Information
Hello. This is the workbench I finished making on November the 12th. It is a combination of both the Roubo and Scandinavian bench designs. It has a shoulder vise, leg vise, and tail vise. The bench is made from hard maple with the shoulder vise chop and sliding deadman made of walnut. I also have two holdfasts to go with the bench. I may eventually make a shelf between the base stretchers, but not sure yet. The top is also removable from the base to make the 250+ lb bench much easier to move. The bench took just over 2 months of full time work to build, but the design was made back in June. I have two 2 1/2" 2tpi wooden screws on the leg vise and shoulder vise, with a 2" 2 tpi screw on the tail vise. The bench is finished with boiled linseed oil.
If you go to the link here http://lumberjocks.com/CartersWhittling/blog/23792 you can see the first blog entry for the entire build of the workbench.
Here are two videos I made going over the bench now that it is finished. In the first video I talk mainly about the design and construction details, while in the second video I show practically how each vise can be used.
Gallery
Comments
· Registered
Now that is a bench !
Beautiful in every detail .
Just wish it was mine !
Congrats and thanks for the videos
Kiefer
· Registered
Very impressive.
You should be proud.
I enjoyed the build blog too.
Thanks for sharing.
· Registered
Just completely awesome. Those dovetails are spot on - flawless.
· Registered
That is one great workbench! All kinds of room and beautiful clamping vises and it looks very solid!!
· Registered
I'm jealous!
· Registered
You can be mighty proud of that bench.
It''l serve you for the rest of your life splendidly!
Beautiful work my friend!
· Registered
I think it came out great! I have been working on a new bench idea and thought I knew exactly what I wanted, but this blog and the wood trex vid have caused me to rethink my design choice! Do i go with Store purchased metal vice hardware or handmade wood screws?! I had made up my mind that I didn't need a leg vise, but now I am rethinking that aspect of the design.
The video tutorial/class on making the tap and die for the wood screws and nut will be a deciding factor for sure
· Registered
This is really a masterpiece - so well done. Enjoyed the blog and wish I had your vision.
Jeff
· Registered
What a beautiful bench or is it a work of art.
If I made that it would be in the front room as a show piece.
Wonderful job!!!
· Registered
Now that is a project that put a smile on my face, wonderful job, enjoy it and don't fret over that first ding, it just means you are using it for its intended purpose.
· Registered
how the hell did this not get a top 3 award i am dumbfounded
· Registered
Awesome job, I will have to watch all off your build blogs. This is an incredible work that I am sure you are very proud of. Great, great job.
· Registered
Great bench and videos. WELL DONE !!!!!!
· Registered
What a terrific bench!!
· Registered
That's one of the finest benches that I've seen and it will serve you for the rest of your life. Congratulations.
· Registered
Tight joints, attention to detail on everything, and those dovetails!! Okay you have made a statement!
· Registered
wonderful bench and great workmanship.
· Registered
a great bench you have made … congrat´s
and the work is very well done :)
it was a a pleassure to see the two vidioclip too :)
thank´s for sharing
Dennis
