Project Information
Hey guys! regards from Spain…
after reading one million posts about roubo benches, buy and read the master book another million, and making space in my workshop I finally decided to go ahead and build it, traditional style, drawbore pins et all.
Top wood is Danta, an african wood, hard as hell and cheaper than beech or maple here in Spain. Was a total chore to dimension it, but finally I managed to put together a big slab of 2,40 meters x 0,65 meters x 11 cm thick.
I calculated the weight of it, somewhere between 70-90 kilos.
The rest of the bench is made of yellow southern pine, and plywood for the drawers.
The leg vise is made of Danta too, with the brass hardware that you can see in the picture, homemade to fit by me. Event the brass plate with the date and my name was done by me using an electrolitic etching technique I saw somewhere in Internet.
Drawers use full extensión guides, and with them now full of hardware and tools, I cannot lift the bench not one single milimeter using all the power in my legs. Two people struggled to lift it a couple of centimeters… weigthing the drawers and body separately, put the thing close to 340 kilos (around 730 pounds?)
The most interesting feature is the self adjusting parallelism of the leg vise. It´s based on a drawing I saw somewhere too, some bicycle chain and sprokets, and homemade hardware. I think that the pictures are self explanatory, but if not, I will try to put a drawing together…
Good think is that that you can put a lot of pressure on a wide piece of wood (or thin, actually works equally well) and the system self adjusts itself so you can forget about taking care of parallelism manually with pins or scraps.
Sorry for my English, I´m doing my best, hope is good enough for you guys…
Luis S.
Gallery
Comments
· Registered
a couple of images more, so you can get a sense of the mechanism… and the cast iron vise on ther side (the leg one works way better!). Hope you will like it, questiions and comments welcome!
· Registered
wow that is beautiful, great work
· Registered
Amazingly beautiful bench TOPO, well done.
· Registered
That is a very nice looking bench. I love the leg vice, i may have to try that on mine as it is a pain to keep parallel. thanks.
· Registered
Crickey that is awesome, the design is amazing and the wood choices too. Thanks for sharing
· Registered
gorgeous bench! have fun working on that! If that's any indication of your woodworking abilities, you're an amazingly talented woodworker!
· Registered
TOPO, wonderful design, and amazing execution. Good job!
· Registered
Great work bench so jealous. Nothing else to say its mind blowing.
· Registered
this is my first post after "lurking" for awhile,and I have to say that is the nicest bench i have seen! very jealous and impressed
· Registered
Awesome!
· Registered
That is stunning work, love the danta wood
· Registered
Awesome bench, and very clever vice configuration. I have never heard of danta, but I sure do like it!
· Registered
Great job! Surprised you have southern yellow pine in Spain, does it grow there?
Good job on your english too!
· Registered
It's more than a workbench…it's a piece of art. Superb job!
· Registered
That is one fantastic looking table. You did a wonderful job thinking and planing this out. Great storage also. I am sure it will be of great use for many years to come
· Registered
Beautiful work Topo. That top looks spectacular! Muy fino!
