Project Information
This was not a commissioned ring, but one I decided to try for fun.
The base of the ring is rosewood, with a channel cut out in the center for the inlay.
Each of the three maple strands were carefully cut to around .5mm and soaked in water before braiding.
I learned a couple things in doing this, and I believe the next one should turn out better (ie. tighter braids)
Finishing is more difficult in this scenario than it is with a smooth-surfaced wooden ring. I'm considering using a thicker viscosity CA or epoxy to totally fill the channel (would have to drop the braids a bit lower into the ring) to get a smooth finish, and offer better protection of the braids.
I'm also experimenting with other woods for the braids, and plan to mix some for color variation in the strands.
Gallery
Comments
· Registered
Very cool ring very nice design
· Registered
that is really awesome…did you just glue the braid to the ring??
· Registered
Really cool, Don't let my wife see this. LOL As I'm a Aircraft Electrician and don't wear rings, she might insist… Real Nice…..............
· Registered
how did you make the channel? If I remember you do not use a lathe…
· Registered
Amazing as always, your bent wood technique still puzzles me. Great work!
· Registered
Many thanks for the kind words, guys!
a1jim: Thank you, sir!
dakremer: I did glue the braid into the ring. Actually, I had to glue a little at a time as I was braiding to keep things together as I moved along.
Lupo: Thanks a lot!
thatwoodworkingguy: Thank you! :)
ken90712: Ha ha! I appreciate the kind words!
rlwilson: In this case I placed the ring onto a mandrel, connected to a handheld drill. I've also done them before by placing the ring flat and turning by hand, scoring the two edges, (craft knife is placed on various thin stock material to alter height, changing width of inlay) and then cutting the middle out. Once the edges are scored clean, the middle is pretty easy.
Blair Helgason: Thank you! As far as the bentwood technique, the trick is to get the wood thin, make it pliable (water/steam), and support the inside (w/ forms) and outside (heavy cloth or simply thumb pressure) while bending. Also, I've realized some folks assume it's a solid piece that's bent and connected with a scarf joint, whereas I actually bend a very thin (1/2 mm) piece around multiple times.
olg28: Thank you very much!
· Registered
that is one nice ring
· Registered
Great work keep at it, everything improves with the next try.
· Registered
Wow! This really caught my eye. (Ouch!)
Wonderful design and workmanship
Thanks
· Registered
levan: I really appreciate that! :)
NormG: Thanks! I hope so. I'm looking forward to hopefully getting better (and possibly faster) at these.
Kent: Many thanks!!! :)
· Registered
O.K. Now youve gon and don it. Those rings are great. It makes me want to try one myself. I went to your site and was amazed.
· Registered
Yup…....Knew better than to show your projects to my wife…...Guess what she wants me to do now…...Your rings are outstanding…........
· Registered
That is a nice ring. How do you create the small strands of the maple wood to braid?
· Registered
Very nice ring. I don't know how that could get any better. Well done.
· Registered
dozuki: Ha! Thank you very much! ;)
busupholstery: LOL! Keep me posted! ;) Thanks!
Jim Jakosh: Thank you! The strands were cut from some thin (.5mm) maple using a craft knife and straightedge (with sandpaper affixed to the bottom, to keep the stock from sliding while it's being cut)
Darryl: Thank you!
Loucarb: Thanks you!
· Registered
wow ,
you are happening !
very well done ,
keep it up ,
these are great !
