Project Information
This remote control caddy is made from Mahogany and is approximately 8-1/2×7-1/2×6-1/2 (the highest point of the arch). The larger opening (3-1/2×6-1/2) can be used for a large remote control or an eBook reader such as a Kindle or Nook like the two shown in the last picture. The three smaller openings are 3-1/2×1-1/4 and 3-1/2×2-1/2 and should accommodate most normal size remotes. The caddy has been finished with 7 coats of General Finishes High Performance PolyAcrylic with 320 grit sanding between the first two coats, 400 grit for the next five coats, and #0000 steel wool for the last coat.
