Showcase cover image for Redux - Great-Grandpa's 10-Ton, 7 Plank Coal Wagon
Project Information
When I first posted this project in May, it didn't have the artwork completed and I had a couple requests to re-post once done; so here is the finished product… alongside a 1:76 "OO" gauge Dapol UK railway model of the original coal car as well…
In the late 1800's through early years of the 20th century my great grandfather owned a mattress factory in Nailsworth, England called the Purified Flock & Bedding Company. While searching for family history info I came across a UK model railway group that had a 1912 photo of the actual coal wagon his factory used. I was also able to find some blueprints online for similar vintage coal wagons, along with some of the 1887 specifications to which the car was originally made. I was intrigued with the thought of making a model of the coal wagon, after all, it's just a box, right? But I was not prepared for the effort required to convert 100+ year old English blueprints for building oak and steel rail cars to a scale model all out of wood, nor the effort required just to get a working brake system, but I think it turned out ok. The original car was known as a 10-ton, 7 plank coal wagon, with a side door, and used a single-side lever brake system.
I rough cut all the oak "planks" on the bandsaw and left them that way to provide the more rugged appearance that I wanted once finished. The "steel" components are mostly maple, with a wee bit of poplar. The "chains" are made of maple. The 200+ "rivets" were drilled and inserted individually. The ebonizing was done using a homemade concoction of steel wool & vinegar, with the wood first being treated to a well-brewed cup of afternoon tea to raise the tannin levels in the wood and help darken the stain. I included a pre-stain photo to better show the rough cut oak, and other details.
Gallery
Comments
Wow- incredible details and craftsmanship. Awesome work.
Thanks for posting.
Bill in MI
What an excellent honouring of your great grandfather to acknowledge him and the business with such a beautifully detailed old railway carriage. Very well done sir.
WOW!!!
Nicely done!!!
- crowie
Thanks Crowie!
Thanks for posting.
Bill in MI
- rtbrmb
Thanks Bill!
WOW…that is a great reproduction in detail!!!!!!!!!!!!!!!!!
Jim
Very well done!
Great model KWB, great detail and love ebonizing… But its like Sonny without Cher without tracks!
What are the dimensions… Is it similar to "T & J" scale?
Premium Member
wow the painting job is just fantastic GREAT JOB :<))) GRATZ TOP 3
- LittleBlackDuck
FOR ALEX : Thanks for the comments. I tried to make it as close to 1/16th scale as I could while allowing for the realities of working in wood. The 1887 specifications for the 10-ton coal car were 14'11" in length by 7'4" in width. The length of the model is slightly longer than 1/16th, at approx. 13" (not including the bumpers) and the width is pretty much right on at 5 1/2". Each of the 7 planks on the sides are almost exactly 1/16th original english oak dimensions. The wheels are T&J 2 1/4" train wheels that I scroll-sawed into spokes and I think they are just very slightly smaller than 1/16th actual UK wheel size.
...Bob
Thanks for your comments Tony; and for passing along the explanation to Alex from the original post.
FOR LBD-I'm not sure Cher would consider herself to be Sonny's "tracks" :) but I get the meaning!! The tracks are on the todo list and I'll just use the T&J approach to build them, but change the scale to fit this car. I found references online stating that the T&J models were 1/16 scale but I've not been able to confirm that. And as you can see from these pics, the coal car is significantly bigger than the T&J caboose & passenger car. Since I wanted to build the coal car based on the original 19th century blueprints I also knew it wouldn't ever be connected with the T&J set as they have very different couplings, so I just stuck with the 1/16th.
Premium Member
this :
Q: What is the size of a model?
A: The models will vary in size between approximately 10" - 30" depending on the model. We typically use the 1/16 scale.
is found on toys and joys website under FAQ's tag :<)))))))
this :
is found on toys and joys website under FAQ s tag :<)))))))
- GR8HUNTER
Thanks Tony… I had seen that but I wasn't convinced of the accuracy of that statement after making the coal car at 1/16 of the original 19th century plans and physically seeing the difference in size. For example, if the T&J passenger car plans are 1/16 scale then the size of the "real" passenger car would be just 24', yet actual passenger cars in early 20th century were 60-70' in length. All moot really, as the T&J plans are meant to be made as its own set so the scale they use only matters if you need or want to add your own cars I suppose.
