Project Information
Seeing that I have a need for a router table and don't have the room. I made the portable table from Wood Magazine, issue 187. Very easy to build and it works very well for as basic as it is. Its made from 3/4 MDF and finished with some poly. I used my old workmate as a stand. Just pull the center board out for motor clearance and clamp it down.
Gallery
Comments
That's a nice clean looking router table. Looks like it will serve you much better that some of the metal bench top models.
Good idea well done
More tools ! I like that. Since it looks like MDF, it's great you have put a finish on it to be slik. I don't see any scratch on it. Brand new?
I believe it's not your only router table, right?
I have a concern about the clamps you are using, unless you put sandpaper under the fence. I have of one these and found out they don't apply much pressure. Check this out since some router bits exert quite side pressure.
Best,
Serge
http://www.atelierdubricoleur.spaces.live.com
Nice looking router table.
Good idea with your workmate.
Serge, yes, it is new and you are so correct about the clamps. I am building some picture frames and ruined one today because the fence slid on me and I did not notice it until I finished my pass. Oh well live and learn. I swapped them out with some 6" bar clamps and worked like a champ. And yes this is my only router table. I will build a dedicated table when I have more room. I guess most WW never have enough room.
You are right Joe. You never have enough room. That is a great idea for a portable table.
Nice looking table and always so little room and so few tools.
Marking this one for inspiration
I like the idea of using it on a workmate table
Thanks for posting
