Project Information
Making this box was an interesting journey. I downloaded sketchup in order to mock up ideas for my new kitchen… but took a small sidestep to see if I could sketch a small teabox that Rah had posted. That ended up in having to create a box joint jig (posted here: http://lumberjocks.com/projects/22112 ).
I finally tested it out properly and am so pleased with that jig. This was just a test. I had planed down some poplar to 1 cm thick and the box joint jig was set up to make a 1 cm box joint. Thanks to the folks who posted responses to my blog. I would have never thought of poplar.
I decided since it was just a test box, I would experiment with finish. The first pic is with a flash, so the color I used to finish looks brighter than reality. The other four pics are closer to the truth.
For the finishing, I first made up my shellac (1/2 cup of super blonde shellac flakes with 500 ml of denatured alcohol). I think the mix is full strength - what you call 1 lb cut? That took about 24 hours to fully dissolve even though I shook and shook. Then I bought myself some pigment (it's called "Mars Violet") and mixed 1/2 cup of the shellac with 1 tbsp of the pigment. I just swooshed it around a bit and it looked ready. I used an artist's paintbrush - ie. something you would use for watercolors - to brush it on. It goes on like a dream. There was a small patch that did not want to take at first but I waited a few minutes and touched it up. It worked like a charm. After 24 hours of drying I put on a few coats of exterior varnish. I am going to keep my glue brushes in it.
The third and last pictures - I call them my money shots. I can't believe that this box is square. And the joints are decent. I see some more projects with box joints in the future. Or more jigs.
Gallery
Comments
Proof is in the pudding.
You aced this one Mtkate!
You are certianly taking on this craft like a lowly apprentice.
Thiat's a good thing BTW.
Whe you build your own finishes and sort out whjat maes thing "tcik" you are well on your way to a happy journey in working wood.
"Money shot" - now that's funny! <vbg>
Maybe it was jsut all that super blond shellac.
Cheers
You are certainly taking on this craft like a lowly apprentice.
That's a good thing BTW.
When you build your own finishes and sort out what makes things "tick" you are well on your way to a happy journey in working wood.
Maybe it was just all that super blond shellac.
Cheers
well done kate ,
i looked at your jig ,
and it looks great .
i guess we'll see lots of box joint projects ?
nice color .
Looking good well done
In Loving Memory
Amazing how much one can learn on a small project like that. You got a nice result too. A sensible way to ease into woodworking. The skills are pretty much the same regardless of the scale.
lol, Bob. Good one on the super blond comment.
Definitely, I have to get my time/money's worth out of that jig. More boxes!
