Comments
I like this vein of experimentation. It catches my interest.
Outstanding design!!!!!!!!!!!!
That turned out great Dianne. like the design and the result. You definitely have me interested in trying some of this art form. Keep them Coming.
Thats pretty damn cool.
Premium Member
Hard to believe it's out of plywood. Good job ….....
I really like that, and couldn't be more aptly named. Looks alive. I think you are getting better, this one has a lot more appearance of motion, which isn't easy with wood. I think it's the undulation.
Nice work. I don't remember anyone asking what tools are you using? I've never done anything except cut plywood, and there is always a friable edge, unless you do something to prevent it. With that much entry into it, I would expect a lot more tear out.
Thanks for posting.
TherealSteveN, thanks for the positive feed back,
I have a couple of tools from Arbortec, that I love and they are great for getting the shaping done and lots of sanding. Being a newbie to woodworking, not 100% sure what you mean by 'friable edge' I,m going to take a guess at the raw edges, please correct me if I'm wrong, but have found that it all smooths out really well.
Very impressed, you have a real artistic flair. I like what you are doing
I think that's pretty cool. Now yer getting into the abstract. Ever thought of adding a bit of dye or stain?
Premium Member
actually - the eye of the artist
things like this just don't happen, it takes an artist to "SEE" the end result way before it happens
and I love the plywood base, nice touch
This turned out pretty cool. I think I might have to try making something like this soon.
Mark, so far I've used a tinted polyurethane to give a little color, I stained the underside of a bowl I made, partly to cover up the filler I had to use to cover up up the bad cut job I did
Premium Member
very cool art piece.sometimes the wood takes you where it needs to go,and the result is beautiful.
- Diane Mc
Anything that can be easily crumbled, crushed, broken, sheared off could be considered friable, and plywood because of it's multiple thin ply's fits that bill. Baltic Birch a little less so because so much care is made to fill voids with the donuts/footballs they use, but along an edge it can crack away from it's neighboring layer leaving large unsightly gashes. Even cutting it on a table saw is sometimes a chore to keep the edges clean. One of the main reasons track saws with their rubber edge lines are so popular. Going at it with a cutter head I would think it would make it more so.
From the looks of it, either that Arbortech head is great, or you have a gentle touch.
Awesome abstraction….finaly some artistic work here.
Love it!!!
