Project Information
I just completed work on a germination stand for my better half's birthday. It is based on a stand I saw over at Indoor Gardening Supplies. Their design didn't really suit my needs, so I re-imagined it to have multiple growing bays and an adjustable light. Each of the "growing bays" has a removable cover that slides into a slot underneath the bottom skirt for storage. This way if we want to put full sized plants onto the bottom shelf we can. There is a timer that allows her to control how often the plant light comes on.
It is 30" high, 30" wide, and 11" deep. Everything is Red Oak from a big-box. There are levelers on all four legs. The bottom shelf was assembled using pocket screws and then I routed out the area for the trays using a rabbeting bit. The trays were simple glue-ups, I used a silver dollar, a jigsaw and some sandpaper to make the rounded edges.
Joinery
There is virtually no joinery here. I used corner brackets from Rockler to secure the legs to the aprons. The tops of the shelves are secured to the aprons using pocket screws.
Finish
This was my first decently sized furniture project so I really focused on the finish. There was a lot of trial and error involved (as was evidenced in this forum posting). In the end I used Olympic's Dark Mocha oil-based stain and Minwax satin polyurethane to topcoat. After staining I used a 1/2 lb cut of clear shellac to seal the stain and prevent the stain from lifting. The last two coats of polyurethane were hand-rubbed. After finishing I polished everything with Minwax finishing wax.
I used steel wool between layers of poly but wasn't pleased with the smoothness on the top. So, on the last three layers of hand-rubbed poly I wet sanded with 400 automotive sandpaper. I can definitely tell the difference.
Lessons Learned
1. I learned a TON about finishing for this project. I really had no clue when I began.
2. I'm slowly getting faster when it comes to cutting and assembling. The finishing on this project took 80% of the time.
Joinery
Finish
Lessons Learned
