Project Information
I recently designed and built this ping pong (table tennis) paddle out of Olive, Mahogany, Walnut, and Cherry wood. It was a fun project to practice joinery and bowties on. In picture #5, there was a void which I filled using reclaimed coffee grounds and super glue (idea from Woodworkers Journal, Issue August 2017, Tricks of the Trade, Coffee Grounds Wood Filler). Thanks for looking! Dale M.
Gallery
Comments
· Registered
I go back to the 60's as an ping pong addict. This is the nicest paddle I ever saw.
Do you suppose you could do something with the finish so I could put some English on the ball?
Dale P.
· Registered
Thanks Dale! (Nice name, by the way!) I'm not fully sure what you mean by 'do you suppose you could do something with the finish so I could put some English on the ball;' if it's possible to reword, i'll do the best I can to answer your question! Thanks for the comment! Dale M.
· Registered
I would never have thought about using coffee grounds as filler. Can you still smell the coffee?
· Registered
Thanks for the comment! When I was sanding the 'filler,' I think I caught a whiff of the coffee but I would say that the finish smell now overpowers the coffee. However, being that I just applied the finish today, that may change. Any other comments/ questions are appreciated!
· Registered
Thanks Charles!
· Registered
What he meant by English on the ball is ping pong paddles either have sandpaper affixed to each side or a thin rubber surface. The rougher surface allows "english" or more spin on the ball when contact is made. Nice looking paddle but to add either would detract from it's beauty.
· Registered
Thanks for the clarification, Hermit! I thought of checkering it similar to the way I checker the pistol grips I build, but as you said, I thought it might take away from the natural beauty. Thanks for the comments- they are appreciated!
