Project Information
This going on 3 year old cedar deck was in desperate need of attention, most certainly it lacked any bit of shade. (The last picture is the before picture.)It got full on sun for about 10 hours a day. It definately needed a face lift also, the cabot semi-transparent I used just one year ago was already faded and peeling. It had blotchey areas as well as areas that there were no longer stain on the wood.
The original plans included some sort of seating area in the Northeastern corner of the deck. That was not in the original deck budget though. Last year, it was over the average high with very little cloud cover most of the summer in Southeast Michigan. This called for several days of sitting out in the blistering sun for 15 minutes then seeking cover for 1/2 hour before repeating. It was not enjoyable.
The options were to put in a retractable awning or a pergola. In my township, gazebos are not allowed. The problem with the retractable awning is the deck is 18ft off the house and the largest awning I could get was 14ft. This wouldn't really look good. We went with the pergola.
Needless to say, I am absolutely certain we went with the right choice. This thing produces quite a bit of shade, a lot more than I orginally thought. It is made from cedar to match the deck, and was assembled with my assistent, MY DAD, and myself in just under 5 hours. The speed which this went up shocked both of us.
We finished the deck with Cabot's Austrailian Timber Oil, Natural and it looks 100 times better than the semi transparent. I know it may need a touch up next year, but with every deck comes deck maintenance, no big deal. Atleast, I can spot-sand and apply an additional coat with out having to strip and sand the whole deck like this year. A co-worker suggested the ATO as he has been using it on his deck for the past few years and is 100% satisfied.
Gallery
Comments
Additional build photos and more finished photos can be seen at www.facebook.com/keencustomwoodwork
Nice looking home improvement project! It looks great. What's a no gazebo rule? I'm just a country redneck who would never buy property with any restrictions. Heck I might want to put a sawmill in my backyard, or build a barn.
How did you attach the pergola to the existing deck? Do the uprights continue down to grade? or are they bolted the the joists? or…...
It looks very nice and bautifully done! How long did it take you start to finish? I've been considering one just like it as my back borch extension. My morning sun is nice and I don't want to block that, but from about 10 to 4 OK sun could be sizzling and a semi covered pergola would be nice.
Gary: The Hot tub is actually being considered!
LittlePaw: It took about 2 years to plan and convince the wife, 5 hours to construct, and about 4 hours to stain it. It does provide a bit of shade and now it is nice to be able to spend hours out there without seeking shelter from the hot sun during the day
Crashn: The main support beams for the deck were installed with this pergola in mind. They lie directly underneath those upright posts you see in the pergola. The posts are resting on the deck's main beams (there are two that run lengthwise parallel to the house) and the posts are also bolted to the joist with 1/2" carraige bolts and post hardware. It is very solid, I was climbing all over it to install the trellis work on top and never once did it shift or move. So to recap, the pergola posts are resting on the deck's main beams while bolted to the joists. That dead load the pergola produces is transfered accross the entire deck and down to the grade through the each main beams 6 support posts that are set 42" deep into the ground and cemented in.
very neat pergola job!
here is another one of our pergola jobs!
Marco, Now that is a great looking Pergola! Poolside dining and lounging, Great Scenary and backdrop! What do you have on the top ?
