Project Information
The aim of this test was to determine horizontal and vertical straight lines, limits and ratios.
Since I have few holes very close to each other, all ratios are simmilar so I put set up with 1,8 :1 vertical and 1,9 : 1 horizontal ratio - on sample 10×60 cm - turned out some 5,5×30 cm.
Regarding limits, the table I used is big enough to make signs aprox. 12,5×30 cm.
I had some trouble to make parallel lines with bottom edge of the table, so in order to make parallel sign I had to angle bottom guide slat some 0,5 degree on right side.
Same problem was to make vertical line - I angled vertical guide for some 1 degree to the right.
That way I determined how I have to put carving pattern to make correctly alligned sign - horizontaly and verticaly in relation to the table edges.
Last, I made some irregular shape and carved it in ratio determined.
Still, I have to test various fonts and shapes, in future.
Gallery
Comments
Premium Member
love your ability to look at a tool or determine whats needed and create it from nothing,you amaze me with your talent.do you have training as an engineer?this pantograph is just one example of your abilities,great job ivan.
Premium Member
a very good test for a hand designed tool …. when you get the hang of it …you will really love this tool you have made …..they are really neat ….. I use to own 1 from sears ..too complicated for me to use …LMAO ….so I end up free handing all my signs …GREAT JOB :<))
Nicely done Ivan. It will be interesting to see what projects you create with this.
Great work Ivan. It truly is outstanding. I really enjoy the things you come up with and your creative mind. Keep us posted on how it goes.
Really interesting Ivan, thanks for sharing this.
Looks good so far. This will be great for sign making. Keep up the great work. I'm working on something now to carve names.
Very interesting Ivan. I'll be watching for your next post!
good job Ivan..looking forward to some fruits of your labor….
It looks like you are on a good path to a working pantograph, keep it up.
Good testing on your new machine> it is very important to know it well before using it on a good piece that you have a lot of work into!!
cheers, my friend…............................................................Jim
Awesome job. Ive been wanting to make one for a while.
amazing work, I'm sure you will make some incredible things with it.
Thanks all for views and comments, ofcourse and contributing to my 37th Daily top 3.
Premium Member
ivan are you counting,its bad luck-lol.congratulations again buddy.
Wonderful to see it running, fine creation, new paths open up.
Best thoughts,
Mads
That's amazing stuff Ivan. Keep on keepin on. Thnx for sharing
Excellent idea Ivan
